Northern California Discussion board for Northern and Central California.
Which torque converter?
Old Feb 14, 2006 | 12:25 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Well I'm getting vibes from the engine while in park and driving from about 1500-2500 rpms.I am going to double check tonight and make sure the flywheel and coverter aren't wobbleing but I'm sure the coverter is causing it.It also has been locking up left and right just cruising so that is getting old.Which converter do you guys with stalls recomend?I don't want to spend too much,maybe 200-250 if that,pretty much as cheap as possible.I want to swap to a t56 when I do the 350 but it's not definate yet.
Old Feb 14, 2006 | 12:55 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
Search ebay, TC that are selling for cheap.
Old Feb 14, 2006 | 12:57 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'll be going through Summit as I get $20 for every 500 I spend at the store.
Old Feb 14, 2006 | 01:03 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
B&M tork master 2400 $239.99(jegs price) not the best of stalls but thats the only one thats under $250
Old Feb 14, 2006 | 01:12 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I could probably go 300 but I have to kinda sneak it passed the wife
Old Feb 14, 2006 | 01:13 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i bought a roadrunner converter from ebay for 170 shipped. capable of 500 hp and stalls out between 2200-2600. I sold it to mysticwizard
Old Feb 14, 2006 | 01:18 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
As long as it's better than stock or at least equal then I'm good.I just talked to Summit and he said that a 2,000 stall would probably be good and it was a b&m for 215.
Old Feb 14, 2006 | 01:26 PM
kairles's Avatar
Engine: 383/LGX
TCI saturday nite special $295.99(jegs price) its a 2000rpm stall they also have the sizzler($214) but thats like a stock stall. if you plan on doing a trans swap I wouldn't get an aftermarket stall get a vette or S10 stall. I think the vette is like 2200 and the S10 would be about the same on a V8
Old Feb 14, 2006 | 01:44 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'm not sure if I'll do a trans swap.I may do the Sat. night special.What stall speed would work best,pros.?
Old Feb 14, 2006 | 01:56 PM
kairles's Avatar
Engine: 383/LGX
for a TPI I'd say 2500ish rpm
Old Feb 14, 2006 | 01:59 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Sorry,converters are new to me,what does the higher stall do really?
Old Feb 14, 2006 | 02:04 PM
kairles's Avatar
Engine: 383/LGX
allows you to bring the engine revs up higher before appling torque to the wheels
Old Feb 14, 2006 | 02:07 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Does it still take off from a stoplight like normal?So instead of power braking and having the wheels spin at 1,600,they would start to spin at 2,400 with a 2,400 stall?How bout on the hwy,what would the diff be?
Old Feb 14, 2006 | 02:15 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
if u don't floor it, it will drive like a normal car. When u floor it from a dead stop it will plant the torque at a certian rpm. For example. let say u have a 2k stall. U idle at 800 rpm. When u floor it, ur rpm will show 2800 rpm then it will plant the torque to the floor. I believe that how it works. Kinda like dropping the clutch
Old Feb 14, 2006 | 02:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I use a S-10 converter behind my 383. No problems so far. Best 60 was 1.71 and that was just off idle with it. Couldnt beat the price from GM under 200 bucks.
Old Feb 14, 2006 | 02:31 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Well,I like to floor it off the line once and awhile.If that's how it works then I will just go with a good stocker.If I hit the gas I want it to go,not rev to 2,800 then take off.It would be good at the track but for daily driving?Wouldn't that feel like a slipping tranny?I'm sure others will chime in and have good input also but I don't want to put one in and not like it.
Old Feb 14, 2006 | 02:52 PM
kairles's Avatar
Engine: 383/LGX
I don't know what phat89ta is talking about. if you floor it it will still go. you wouldn't know it was slipping. its more like its not appling all the power until the the stall speed. I have a friend that had an ls1 camaro with a 3000 stall and it would light up the tires off idle
Old Feb 14, 2006 | 03:15 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Well,Del and Travis have'em and I don't hear them complaining.I need to take a ride in one of their,sorry Travis,Dels car and see how it does.Problem is I want to out the new one in asap.I'm taking the tranny out of my 87 runner saturday and taking it to Fresno for a new one.So I should do it this weeknd too.
Old Feb 14, 2006 | 04:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
from first hand experience with my 2400 stall, no difference when driving like normal, but if u punch it off the line, it slips more up to its rated stall speed, so its bringing the rpms much faster to that specific rpm.
your supposed to want a stall rated right under your peak torque.
so for a tpi, 2500 is about right.
Old Feb 14, 2006 | 06:04 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Even for a 305?I was thinking of going with the2,000.What about while you're cruising,would you feel it slip till it got to it's stall speed?
Old Feb 14, 2006 | 07:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
no
Old Feb 14, 2006 | 08:32 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Picking a stall can help/hurt your ride if you don't choose correctly.
Your stall now is in the 1600's somewhere I think, and moving it to 2000 shouldn't be too much of a difference until you hit the track and are able to hold those rpm's higher.
Personally, since you're changing the motor/tranny maybe later, I wouldn't waste the $200 and time to drop the tranny if it ain't broke.
If you're set on doing it, I would go with 2000 or lower if stockish if cheaper, because I don't think you'd really utilize a 2400+ as it stands.
I don't take full advantage of my 2400 stall as much as I should, hopefully I can work on that this year.
Old Feb 14, 2006 | 08:37 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
If it needs it then I may as well buy a decent one to hold me over.I just need to unbolt the tc and see if the vibe still exists.It may just be in need of a tune up which I will also check.I do on the other hand need to buy a new slip yoke and ujoints,they are really bad.
Old Feb 14, 2006 | 09:00 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i think a good 2200-2600 stall would be good for 305 and 350, if ur getting a 350 and still keeping the tpi
Old Feb 15, 2006 | 11:23 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
A 2400 or 2500 would work fine for your application. I'd recommend something with a low STR rating so that you don't just roast the tires on take off on your street tires.
If you drive a stalled car normally you don't feel a difference. As soon as you step on it the rpms rise very quickly to the stall speed and the full amount of power is applied through the converter. The STR rating also plays a factor in how much power is multiplied. Also decide whether or not you want to pay for WOT lockup capability.
If you're swapping trannys and you're positive it's the converter, just buy a stock replacement. $130 from natpro.
Also you WILL need a tranny cooler with an aftermarket stall. Heat is an auto's enemy and an aftermarket stall gets hot quick. B&M sells some for about $40 bucks and they're decent.
Old Feb 16, 2006 | 08:21 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
make sure to get a transgo shift kit. damn steve u straight overhauling ur car.
Old Feb 16, 2006 | 10:44 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I have been purchasing a few things for it My tires were 900 bucks.Some guys the other day wanted me to do a burnout but I just got the tires and I'm not wasting them.
Old Feb 16, 2006 | 11:59 PM
Car: '89 GTA
what kinda tires did you get for 900??
Old Feb 17, 2006 | 12:34 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
better be slicks all the way around!
Old Feb 17, 2006 | 09:00 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I bought Falken Fk451's.It actually came to 876.They were the tires that I bought for the mustang and I liked'em.They grip really well.The other day on the way to work at 6:30 in the morning some guys flashed me and when he passed and I could see again I noticed that somebody had hit a deer and it was in my lane.Now I scrape on pine cones so this thing would have ripped off my bumper.I had to jerk the wheel really fast to get around it and the car stuck to the road really well and that was at 60-65.They are for 18's so there a bit more expensive.
http://www.falkentire.com/tires_451.htm
Old Feb 24, 2006 | 11:23 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
Heres an inside video of an ls1 with a 3200 stall. It gives u an idea of what u expect with a higher stall.http://videos.streetfire.net/search/...25A2F4ED5C.htm
Heres another one with a 3800 stallhttp://video.ls1tech.com/search/stall+converter/0/3E827636-289D-4195-98C2-484B670898F1.htm
Old Feb 26, 2006 | 01:48 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
That was an annoying video to watch.I will just have to take a ride in a car with one.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
