rocker clearances..
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
rocker clearances..
Are there any clearance issues with 1.6 Crane Golds and the stock centerbolt valve covers? im really not in the mood to be smackin the rocker against the cover...
please send me a pic of them if u get a chance. Ive heard they wont smack, Im still runnin stock pushrods from the heads
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
Originally posted by JesasaurusRex
narrow self aligning type i had no problems
Did you remove the baffles?
no I havent. I thought about it but wasnt sure if it was necessary at that moment. U think thats a good idea?
Originally posted by Dwayne88IROC
I went with comp cams rockers and guide plates after a fit check of the self alinging type.
Car: Cars
Engine: SB
Axle/Gears: 9bolt
I wasn't clear - I was also talking about the crane golds and they hit my stock valve covers. I had hardened push rods so I went with the guide plates and easy to find and rebuild Comp cams Magnum roller rockers.
My after market covers do not have metal baffles they use baffled rubber grommets that work fine.
JesasaurusRex - what heads are you using?
Car: Cars
Engine: SB
Axle/Gears: 9bolt
currently AFR 220s, when i had the crane golds 1.6 self aligning narrow body i was using vortecs with stock valve covers
How is your t-5 holding up to the 412?
I fried mine with a 305!
New2Chevy
Sep 28, 2015 12:35 AM
