Northern California Discussion board for Northern and Central California.
So.......
Old Mar 26, 2006 | 08:27 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
So.......
I've had this Holley adjustable fuel pressure regulator sitting in the back of my car for the past 2 yrs. I pulled plenum off today and put it in. When I started the car with the pressure guage hooked up to fuel rail, the most I could get out of it was about 45 psi. Am I missing something simple or is my fuel pump on the way out? I noticed that when I gun the engine, the fuel pressure jumps to about 50 psi. Anyway, I can't search for anything ('cept w/ google). Someone tell me what I'm seeing is normal.
Old Mar 26, 2006 | 10:19 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
well aaron are you disconnecting the vacum line when your checking the fuel pressure?
make sure that the vaccum line is disconnected when checking fuel pressure,
Old Mar 27, 2006 | 12:43 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
disconnected and pluged mind you.
also check how fast the pressure bleeds down after you kill the engine.
Old Mar 27, 2006 | 08:30 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Sweet. I picked up a guage that has a clear plastic hose on it. Dunno if I'm supposed to connect that to the vacuum on the afpr. I hadn't disconnected the vacuum line though. I'll give it another try.
Thanks guys.
Btw... are we still on for dyno day on Sunday? What time should I show up?
Old Mar 27, 2006 | 09:14 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Yes we're still on for Sunday, time is TBA, but I'm sure anytime after 9-10am should be fine.
Check back again by Friday in the GTG thread and we'll have the latest.
Should be a great 70* weekend.
Old Mar 27, 2006 | 09:18 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I hope so because its been crap lately.
Old Mar 27, 2006 | 09:24 PM
Car: '89 GTA
yeah, no doubt.
extended forecasts say all clear by friday.
should be high 60's-70 sat/sun.
Old Mar 28, 2006 | 02:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I can't wait im all giddy like a school girl.
GTA Sammy
Jul 24, 2012 08:24 AM
Stephen
Fabrication
Apr 20, 2010 10:30 AM
vortek
Exterior Parts for Sale
May 18, 2009 07:56 AM
412smallblock
Brakes
Feb 4, 2009 01:55 PM
easySPEEDcamaro
Apr 21, 2003 01:22 PM
