4th gen 10 bolt axle-------FS
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
It is out of a 96 RS. Ring gear(41)/Pinion gear(12)=3.4166667 rear axle ratio. Yes, you read it right. I thought it was a 3.23 axle ratio but found out late today when I disassembled it. It is all apart at this time and I'm in a process of replacing the both pinion bearings due to loud whine. All other bearing are in great condition. If any of you guys are interested, let me know. I will let it go for $600.00 complete with brand new rotors and pads. And yes it has calipers too of course. It's complete guys. If you want all bearings replaced then few more $$$ will be needed
You can reach me at my cell phone:916-715-4516
You can reach me at my cell phone:916-715-4516 Trending Topics
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Hey Benny, when you read this, let me know if you can let just the axle go. Thanks. I don't need/want the brake setup.
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Travis, if you buy his let me know what you want for your current rear. What it will come with etc. If you decide to sell it. You have the pbr's right? I would need to find some if that's the case.
Car: '02 Z06
Engine: L33 5.7
If you are disc right now, It would all bolt up. I'd let my axle go for 150. Thats about what I paid for it. All I want is the 4th gen axle so I don't have to run as big as spacers for my wheels.
Car: 00 Camaro SS
Engine: 5.7
They are disc right now, so I would just swap my stuff over. Does it make any noise? If not I'll take it, just tell me if/when you buy his.
Car: '02 Z06
Engine: L33 5.7
Everything swaps over, remember, I got this Axle from an 85 iroc, That was pre-pbr, I had to order backing plates from a 91-92 PBR camaro to get my calipers to work. But since this axle was pre PBR, your stuff will bolt right up.
ambainb
Apr 25, 2016 09:21 PM
