Tire Size??
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Tire Size??
i need to know if these tire size will work before i spend 1100 on them
Front Rims 18x8 with a 4.5" back spacing
Rear Rims 18x9 with a 6" back spacing (4thgen rear)
Tires
Front tires 245/40/18
Rear tires 275/40/18
Will these be fine with my ride??? The car is not lowered... Thanks guys... the tire guy has no idea what im talking about
Joey
Tires
Joey
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I have a pro kit with 18x9's all around with 255/35/18's in the front and 265/35/18 in the rear and I have too much fender gap so you should be fine.
Car: Camaro RS/SS
Engine: 5.7 LS1
Awesome, They said that the 35 isnt that much difference with the 40 series??? Ok then, thats good to hear. Thanks bro
Car: Camaro RS/SS
Engine: 5.7 LS1
That is a good amount of tire still huh??? if your going to work at tire place, at least know what your talking about... LOL Oh well just as long as i get what i want. To returns
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
245/40/18 should be a 25.7" tire(stock height). the 275/40/18 should be a 26" tire. both will be fine even if you lower it some.
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Your rear tires will be around 26.66" tall, so almost 1" taller than your fronts. Still, they should all fit. I have a 285/35/18 in the back on a 10.5" wheel and roughly a 2" drop with no rubbing. I've also had up to a 275mm tire up front on a 9.5" wide wheel (any wider and you are going past the fender lip) with just slight rubbing at full lock. So it can be done..
Axle/Gears: 3.73:1
Yes, let me dig some up. It looks like crap because the clearcoat is peeling and I haven't gotten around to painting it.
Axle/Gears: 3.73:1
Here's a pic with the hood up, it doesn't show the bad paint too much.
The only thing different about the car now is the charge pipe you see under the passenger fender is now painted black and tucked up a bit further. Anyway, I think the wheel offset is about perfect.
The only thing different about the car now is the charge pipe you see under the passenger fender is now painted black and tucked up a bit further. Anyway, I think the wheel offset is about perfect. Thread Starter
Car: Camaro RS/SS
Engine: 5.7 LS1
That looks sweet bro!!! Yeah thoes wheels do fit perfect.
Car: 00 Camaro SS
Engine: 5.7
Looks like I'm going to have to head over to Sparks sometime and take a better look.Maybe1 of the times I go to Summit.
Sorry for the hyjack Ramair.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
