Northern California Discussion board for Northern and Central California.
GTA weight
Old Oct 8, 2006 | 05:01 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
GTA weight
I was looking at some old paper work for my car and I found the smog paper from when i bought the car, it says "test weight 3,750lbs." Is that how heavy my car is or did they just make a guess?
Old Oct 8, 2006 | 06:45 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Curb Weight: ~3550lbs max, so if he's estimating with his weight in it, could be accurate.
Old Oct 8, 2006 | 07:04 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
my 94 fully loaded TA weighed 3750 with me in it, so i'd imagine that's pretty accurate for a loaded weight - not curb though.
Old Oct 8, 2006 | 08:19 PM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
speaking of weight. how heavy is an aero wing spoiler?
Old Oct 8, 2006 | 08:37 PM
Car: '89 GTA
Now you're asking tricky questions, haha.
I think about 25-30lbs. Why do you ask?
Not sure how light the new ones are, but I'll be getting one eventually.
Old Oct 9, 2006 | 02:19 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
3850 without driver
Old Oct 9, 2006 | 03:01 PM
G-Ride14's Avatar
Car: 1988 GTA
Damn, our car's are boats! My mustang with me in it weighs 2900.
Old Oct 9, 2006 | 05:15 PM
Car: '89 GTA
3850 without driver
What car are you refering to Harjeet?
Yeah, definitely at a weight disadvantage, just takes a little bit more to make them faster, or some creative weight savings.
Old Oct 9, 2006 | 07:46 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
[QUOTE=OUTATIME GTA;3086673]What car are you refering to Harjeet?
my 89
Old Oct 9, 2006 | 08:40 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
when you smog a car it only weights the drive axle(front or rear of car), so its kinda like a guess. my Iroc's smog paper work say's the same thing my moms old s10 blazer(97 2 door 2wd) said 4500. I don't think a smog station scale is very accurate for total vehicle weight.
Old Oct 10, 2006 | 01:30 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Would a weight number higher them the actual weight of the drive axle be a benifit to the smog test?
Old Oct 10, 2006 | 01:59 AM
kairles's Avatar
Engine: 383/LGX
no. more weight more load. more load more stress on the engine. you see where Im going
Old Oct 10, 2006 | 02:02 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I do, but do you know what I am saying? car over axle weighs 3000lbs, you input into the computer, 6000 pounds, this will effect smog numbers won't it?
Old Oct 10, 2006 | 02:16 AM
kairles's Avatar
Engine: 383/LGX
only weight you put into the machine is the GVW and thats more of just confirmation. you drive onto the scale and it shows the weight and you hit enter.
yes it could effect smog numbers.
example: run down the street. then get a backpack and put about 20lbs in it. then run down the street with it.
Old Oct 10, 2006 | 02:46 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
so what effect does it having on you inputting the correct weight?
Old Oct 13, 2006 | 08:05 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Stock mine weighed in at 3550Ibs
Old Oct 13, 2006 | 11:11 PM
Car: '89 GTA
That is the correct weight, give or take depending on year.
What is your setup running at the track these days Tony?
Old Oct 15, 2006 | 01:06 AM
Tony89GTA's Avatar
Car: 89 GTA
Arg! probably terrible lol, before this new ford 9" rear I was doing a 12.8, not sure how she is going to run now with the extra wieght from it and the change in gear. I'll probably going to be adding subframe conectors soon to if I get off my lazy fat *** and install them, been sitting in the box for 2 years now
Old Oct 15, 2006 | 09:46 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
for those of you that wants to weigh your car, we can do that at the shop today.
Old Oct 15, 2006 | 09:04 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I got 1250 rear, 1600 front
total of 2850 lbs? Thats without me in it.
Veaceonee
Sep 29, 2016 08:15 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
okfoz
Sep 15, 2015 05:22 PM
timonator
Sep 11, 2015 05:11 PM
