Northern California Discussion board for Northern and Central California.
Got my shortblock back
Old Apr 13, 2007 | 11:37 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Well I got my shortblock back today but to my surprize, it wasn't assembled. I already drove down and couldn't wait for them to assemble it so I took it and will do it myself. I wanted to motivate myself a little so I mocked it up tonight, I'll start on the assembly tomorrow.
I moved this last week too and i now have a 3 car garage, the single is reserved for the Formula I'm towing the car over tomorrow and will get pics of it's new home. The single side is blocked off so I don't have to worry about anything hitting it.
Old Apr 13, 2007 | 11:44 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Re: Got my shortblock back
i hope you didnt pay for them to assemble it
she is lookin nice though you should remove that overspray so it doesnt get into the oil carb cleaner works good.
man let me know a day so we can put that baby back in ill schedule it in advance
Old Apr 13, 2007 | 11:48 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I still need to pick up the right measuring tools to put it together. Hopefully I can find a decent set for cheap as I don't plan on building many more for awhile.
There's no overspray, maybe it's just shadows.
Old Apr 13, 2007 | 11:54 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
sweet
Old Apr 14, 2007 | 01:38 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
What tools do you need?
btw, thanks for chatting with me tonight, I'm defintely taking my parts over to hines for balancing but I will probably assemble myself as well, no need to have someone else do it now, Goulds already prepped my block for the pistons, so I just need to slap everything together now. Block was already line honed the 1000 miles ago when I first assembled it and zero decked so it should be good to go. Did you ever verify by chance if your damper has a counterweight on it or not?
Old Apr 14, 2007 | 01:50 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I'll go look now. They didn't have the damper when they balanced it, should they have?
Edit, no weights on it.
I need the dial indictor to check for play. I need to check bearing clearances too.
Old Apr 14, 2007 | 01:52 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
no they shouldn't and thats why I argued with goulds and I am not letting them balance my schit
Old Apr 14, 2007 | 01:55 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Did Gene know you knew me? Did he tell you anything that he was doing? He lfet the receipt a little unclear. I'm calling him monday.
Old Apr 14, 2007 | 01:58 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I told Gene I knew you, all he said was that your engine was ready and you were picking it up friday.. That was wednsday. Glad theres no weights on it, it didnt look tampered with at all either right?
Old Apr 14, 2007 | 02:05 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Are you looking for weights attached to the damper? If so then there's nothing. I can get a pic if you want. I can do it now.
Old Apr 14, 2007 | 02:07 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
No its fine I believe you , you would recognize them if you saw it. I am gonna go to sleep now. see ya tomorrow.
Question for the night: what headgaskets you running?
Old Apr 14, 2007 | 02:15 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Not sure yet,AFR recomends Felpro #1003 for up to 4.100 and #1034 for 4.100 bore or larger. I'm researching now for a good gasket.
Attached Thumbnails Got my shortblock back-100_3051.jpg   Got my shortblock back-100_3052.jpg
Old Apr 14, 2007 | 02:01 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
i didnt like the 1003 head gasket its bore is too big when i had it on my car
i would go with a cometic head gasket the closest to 4.030 is this one
http://www.cometic.com/da_viewimage.aspx?da=2
you can also go to their home page to view all about their head gaskets
http://www.cometic.com/faq.aspx
Old Apr 14, 2007 | 05:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i think you should go for a 4.06 - 4.09 bore gasket
Old Apr 18, 2007 | 11:06 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
What do you guys think of this cam? I may go wi this instead.
http://store.summitracing.com/partde...8&autoview=sku
Old Apr 18, 2007 | 11:27 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
thats a pretty good size... id Say GO FOR IT!! Its going to sound really mean at idle...
Old Apr 20, 2007 | 10:31 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Shortblock is together so I hope to have the engine mostly put back together this weekend. I need to make a trip to Summit though. Here's a pic of the block and the garage the car will be in. I have to clean it up tomorrow as I still have most of the stuff from the old garage in the single side.
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
