FS: BBK pulleys
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
FS: BBK pulleys
decided not to run these anymore. didn't have any cooling or charging problems. Im sure I've driven no more than 1000 miles with them. I should have them off in a week or two.
$100 w/belt
$100 w/belt
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
Re: FS: BBK pulleys
Might I ask the reason for getting rid of em? I was thinking of picking some up...
Engine: 383/LGX
Re: FS: BBK pulleys
I been thinking about adding a sub and amp, and the volts sit just under 13 at idle with everything runing.
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Re: FS: BBK pulleys
use the stock alternator pulley and you'll be fine.
Engine: 383/LGX
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: FS: BBK pulleys
are these serp or v-belt pulleys?
Re: FS: BBK pulleys
they are serpentine belt set-up. i know because i was the one who installed it.
Re: FS: BBK pulleys
I'll kick around the idea. I haven't decided whether to use underdrive on my new setup. Thanks
Will
Will
Re: FS: BBK pulleys
It isn't lol. The motor is at work, the cam came in last week. Waiting on a degree kit to get that baby dialed in and then it's who knows how long before I get to run it. The car needs a lot more work, but the motor was the last major component I was waiting for. Just need to do a little front end suspension work and I should have the car rolling in a couple months.
Will
Will
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: FS: BBK pulleys
You're set up with Paypal arn't you???? Nitro
bigjay89gta
Oct 15, 2015 08:04 AM
IROCNParts
Sep 24, 2015 10:50 AM
