Northern California Discussion board for Northern and Central California.
over heat
Old Sep 30, 2007 | 09:55 PM
whiteonwhite_rs's Avatar
From: sacramento ,ca is were i live so if you c me on the freeway get out of the way
Car: 1989 chvey camaro
Engine: 5.7 v8 tpi
over heat
ever since i put my new engine in my car has been over heating wat should i do ...............
Old Sep 30, 2007 | 10:57 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Re: over heat
Start with the obvious and cheap 1st. Is it possible you have an air pocket(s) in the coolant? Is there enough coolant? Is your water pump/ thermostat working? Where did it run temp. wise before? Was it a 350 to 350 swap, or did you have a smaller motor before? My 3rd gen Camaros have always ran warmer than I liked. I bought a 3"cowl induction hood from Harwood, a 185 thermostat, removed the A/C condensor from infront of the radiator, put a Griffin 3row alum. radiator in, and had both my fans programmed to come on at about 190 degrees. On a cold night, the needle almost rests at the bottom of the temp gauge. Is the little air dam below the car intact? Anything blocking the radiator?
Old Sep 30, 2007 | 11:08 PM
Engine: 5.7 v8 tpi
Re: over heat
yea there is enough coolant wen i repalced the engine i put in the new water pump but i didnt put in a new thermostat i have it but i didnt put it in yet and i went from a 305 to a 350 and my gets so hot it smokes and the coollant starts to boil but im not sure if my fan is even coming on let me check and i'll get back to u on that
Old Oct 4, 2007 | 10:33 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Re: over heat
Do you have 1 or 2 fans. When do they come on. Do you over heat on the freeway as well as in town? Are you carbed or injected? Your radiator may be undersized for the extra motor. When was the last time you had it(radiator) serviced/flushed? My previous Z/28 always ran warm in the summer, but with the mods I've done to the IROC, she's fine. You may want to check if your to rich. Where's the smoke at or coming from?
Old Oct 5, 2007 | 01:40 AM
Engine: 5.7 v8 tpi
Re: over heat
i only have one fan and i havent seen them come on at all since i got the new engine put in um every time i drive on the freeway and my girl was drivin it the and she said it started gettin hot and it was jerkin and then there was smoke all in the car so she pulled over to the side of the road and cut the car off and it wouldnt start back but it starts i cant tell where the smoke is comin from
Old Oct 5, 2007 | 02:17 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Re: over heat
Well if your fan(s) don't work, you'll overheat in town. Did you have any overheating problems before the swap? Is it an electric fan?
Old Oct 5, 2007 | 07:18 PM
Engine: 5.7 v8 tpi
Re: over heat
no i never had problems before and its the stock fan the car comes wit
Old Oct 7, 2007 | 10:49 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Re: over heat
Is there power(electric) or drive(if manual) to the fan? Find out why your fan isn't working. Then, when that's fixed, let us know if you still overheat. My fans come on around 190 deg. My thermo is set for 185-190 deg. Any pics of your cars underhood will help.
Old Oct 8, 2007 | 03:01 AM
Engine: 5.7 v8 tpi
Re: over heat
ok i will post some picks in the morning and do u think i should go a singel or dual fan if i do replace it
Old Oct 8, 2007 | 03:32 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Re: over heat
If you can afford it duals are always better IMO. There are some after market companies out there that may have a better single electric fan than the one you have. Remember, if you don't have an electric one now, you'll need to wire it. I'd also recommend pulling the radiator and having it flushed. I replaced mine with a 3 row Griffin. Also replace that thermostat. Did you get a new water pump when you replaced the motor? If your fan(s), water pump, radiator, thermo work, and your system is sealed, we can move on from there. Also, when you pull the radiator, check for debris between your a/c components and radiator. Get pics up of entire engine bay. Also a shot of the front of the motor from different angles.
Old Oct 9, 2007 | 07:03 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Re: over heat
What is the timing set at?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
