Northern California Discussion board for Northern and Central California.
My List for '09
Old Jan 10, 2008 | 02:52 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
My List for '09
Dang thing has grown!
  1. Front struts, balance, align
  2. Front end bushings: I ordered the Energy Suspension kit from Summit for 100 bucks.
  3. Rear axle - This includes a bunch of little projects like replacing the rear pads, e-brake cable, service diff, etc...
  4. Master Cylinder - Need a new prop valve now because the old one is bad and the new rear axle requires a different one anyway.
  5. Paint: Do it right this time.
  6. Interior - Still on the look out for that reasonable, tan leather interior from a 3rd or 4th Gen.
All this totals to around 4 thousand bucks if I do it right and/or have a mechanic do it for me.
Maybe an engine swap would be a better expenditure of cash.
Old Jan 10, 2008 | 06:58 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: My List for '09
The only expensive thing on that list is the paint! You should get tan interior from a 5th gen!
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: My List for '09
'09?
I must've slept right through '08. Dang, and I had so much to do this year... umm, uh, I mean last year. I hate it when I oversleep!
Old Jan 10, 2008 | 08:14 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Re: My List for '09
My goal is to get a good clutch in my Camaro, then get a procharger for it...Baer brakes...New wheels and tires.......
I see where this is going...
Jason
Old Jan 10, 2008 | 10:43 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: My List for '09
I just waant to get mine done and running. I should be able to do that.
Mike, When do you want to look at all your parts?
Old Jan 11, 2008 | 09:51 AM
Cadillac's Avatar
Re: My List for '09
Originally Posted by LAFireboyd
'09?
Oh man. I'm working too much on fiscal year planning. April is EA's fiscal '09 and might as well be my car's too. Either that or my wife is going to prohibit the spending and it won't happen until '09 anyway.
How you lookin' tomorrow morning?
Where and when?
Old Jan 12, 2008 | 02:53 AM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Re: My List for '09
Here is my '08-'09 to-do list. Apparently I am doing a complete frame off restomod on my 1991 Formula since this is a lot of crap...
Interior:
Dash pad
Carpet
New clean looking seats without boy racer wannabe look
Fuel pump access door
New headliner (ABS?)
Repair/replace center console due to bulging sides
Clean up wiring to speedo conversion box in console, install connector for easier console removal
Replace lower shift boot
Exterior:
Address stress cracks in roof
Fix crack/dents in drivers door or replace door
Replace door hinge bushings
Fix chips/scratches in spoiler
Fix rust on a-pillar, left rear quarter, rear decklid
Repair scratches in front bumper cover
New passenger front fender/eliminate antenna hole
Clean underside of car and possibly coat (POR-15?)
Design new wheelwell liners for cleaner look, better tire clearance, and brake cooling duct capability
Have Fiskse outer wheel halves replaced and refinish centers
New tires
Paint
Tint
Suspension/Brakes:
Buy panhard bar with rod ends for Moser rear
LCA relocation brackets
Finish brake brackets for rear PBR brakes
Adjustable brake proportioning valve
Upgrade shocks - Koni or Tokico?
Adjustable torque arm(?)
Design better exhaust hanger for cat section and rear section of exhaust
Clean up spindles and hubs
Wider front wheel adapters for wider track
Drivetrain:
3" Chromoly driveshaft
I think I can do it all for a reasonable cost.
Old Jan 12, 2008 | 05:37 AM
JesasaurusRex's Avatar
Re: My List for '09
08
Chop off Travis
Old Jan 12, 2008 | 11:27 AM
Comp788's Avatar
Re: My List for '09
Mike, Are you free Sunday?
Old Jan 12, 2008 | 01:02 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: My List for '09
Originally Posted by JesasaurusRex
08
Chop off Travis
Old Jan 12, 2008 | 01:22 PM
Cadillac's Avatar
Re: My List for '09
Yeah. Should I call you tomorrow?
The car is actually in the shop now:
  • New shocks/struts: KYB GR-2's again on all 4 corners.
  • Energy Suspension Bushings. All 'cept motor and tranny mounts.
  • Align
  • Balance
Big Football day today and tomorrow... Pulling for anyone but the Pats and 'Boys.
Old Jan 14, 2008 | 12:56 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
Re: My List for '09
go faster
Old Jan 14, 2008 | 10:59 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Re: My List for '09
Originally Posted by valencia1z
go faster
You have a PM...
Jason
Old Jan 25, 2008 | 02:56 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: My List for '09
rebuild front end-parts are ordered as of now
rebuild transmission
NOS
be somewhere in the 13's by th eend of 2008
Old Jan 25, 2008 | 04:14 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Re: My List for '09
If I don't end up moving to Idaho, this is my 08 list.
Cammed Lsx
Long tubes
Magnaflow catback
T56
3.73 gears
finish my Zo6 brakes
New steering wheel (stock, current is ripped)
finish stereo
Old Jan 25, 2008 | 04:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: My List for '09
My '08 goal? Have the car painted, interior all done and have my motor at the very least be very reliable.
Old Jan 25, 2008 | 07:09 PM
Comp788's Avatar
Re: My List for '09
My list is get the car running at hit 12's first time out.
Mike get your car back? We still need to look it all over to find out what we need to do to get the rear end in there.
Old Jan 25, 2008 | 09:59 PM
Cadillac's Avatar
Re: My List for '09
12's on your first time? I'm guessing that'll be easy.
Yeah. Thousand bucks later I got it back and it rides great. I just need that new MC in sooner rather than later. The brakes are still the weak part in the drive. Parents-in-law in town this weekend but I might could do a quick, early morning.
Here's the list of parts I have now:
  • Axle with disks and hard lines. Might need to replace the pads (don't have) and inspect the rotors.
  • 9-bolt diff cover gasket. I want to change the fluid. Need some royal purple or something.
  • E-brake cable. One on there now will not work.
  • Master Cylinder and prop valve.
Pretty sure those are the obvious parts. I need someone who knows their way around the underside of these cars to tell me what else I need. I figure that's you, Brett. Your car has been overhead every time I've seen it.
EDIT: Updating the list:
  • eBrake cables: The ones that attach to the center cabel and actually actuate the caliper.
  • GM Posi Additive, Mobile 1 synth diff oil (75/90W) X2
  • Brake pads
  • Idler arm
Old Jan 26, 2008 | 01:05 PM
Re: My List for '09
Cammed Lsx
Long tubes
Magnaflow catback
T56
3.73 gears
finish stereo
yea, i heard those LSx motors that don't have cams don't make too much power
Old Jan 26, 2008 | 05:14 PM
Comp788's Avatar
Re: My List for '09
Mike,
Great to see you this morning. Let me know when the parts should show up. I am sure we can do it in half a day. The swap will be easy, as long as nothing comes up part wise.
We can look at the suspension. I'll get that thing to drive like new. People just don't know what to look at. Your brakes are fine. Somthing in the suspension is worn out.
As long as I don't miss a shift. 12 should be easy.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Dragonsys
Sep 25, 2015 03:51 PM
