Northern California Discussion board for Northern and Central California.
Recommendations For SFC's Install
Old Feb 4, 2008 | 12:39 AM
Jboat87's Avatar
Car: 1987 Iroc-Z
Engine: 305 TPI LB9
Transmission: Borg Warner T-5 5 Speed
Axle/Gears: Borg Warner 9 Bolt 3.45 LS
I just ordered a few goodies from Spohn. I went with the front and rear swaybar kit, the lower control arms, and the subframe connectors. I can do everything myself except the welding part. Does anyone have any recommendations for a good welder who is experienced with installing these on 3rd gens. I'm open to suggestions anywhere in the Bay Area or Central Valley...
I want these done right...
Old Feb 4, 2008 | 06:12 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Recommendations For SFC's Install
Ask Benny if he can help you out still
1tuf92z..
Old Feb 4, 2008 | 12:05 PM
Jboat87's Avatar
Car: 1987 Iroc-Z
Engine: 305 TPI LB9
1tuf92z..
Pm'd him, thanks...
Old Feb 4, 2008 | 01:55 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Also talk to Comp788, he was going to do mine for a good price.
Old Feb 5, 2008 | 12:13 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
See Vin?
I told you he wasn't going to keep the car stock.
Old Feb 5, 2008 | 12:46 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Not my car, could care less whether he mods it or flys to the moon on it.
However my custom mod of no motor / trans or interior when I got my car sort of made the decision that I had to mod it. If I had a creme puff like that I probably would leave it closer to stock than my car but...
Old Feb 5, 2008 | 12:14 PM
Jboat87's Avatar
Car: 1987 Iroc-Z
Engine: 305 TPI LB9
Originally Posted by Cadillac
See Vin?
I'm not changing the visual appearance. How's that...
And these aren't mods, they're necessary upgrades...Yeah, that's it...
I found someone in Modesto who's gonna do them for me...
Old Feb 6, 2008 | 08:15 PM
koolctk's Avatar
Car: 1989 Trans Am GTA
Take caution when you have them done no matter what.
Try to get a fan on the weld spots and I even suggest pulling up the carpet if you have the time. Make sure, at the minimum, you take your time. Don’t let the welder try to weld it all in 20-30 minutes, and make sure you have an extinguisher that actually works nearby.
Cameron
Old Feb 8, 2008 | 11:41 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
VERY IMPORTANT if you don't want to BBQ your ride!
Old Mar 4, 2008 | 03:18 PM
Jboat87's Avatar
Car: 1987 Iroc-Z
Engine: 305 TPI LB9
I got them done yesterday. I took the time to remove the carpet so no worries. Now I just have to put it all back together...
Here's a link to the other post with pictures...
https://www.thirdgen.org/forums/susp...ml#post3664321
Old Mar 4, 2008 | 03:43 PM
Cadillac's Avatar
OMG that car is clean. Makes you want to scrutinze those welds real hard and stuff.
Are you considering attending the Sacramento GTG early April? If we can get Brett's car ready and a few others we could caravan.
Old Mar 4, 2008 | 04:08 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Anyone have any recommendations for sfc install in Fresno?? I called a bunch of exhaust shops and they say they have to see it. If they dont even know what they are then I dont want to take it there. Anyone know someone reputable in Fresno?
Old Mar 4, 2008 | 04:20 PM
Jboat87's Avatar
Car: 1987 Iroc-Z
Engine: 305 TPI LB9
I have a pretty non standard work schedule so it depends on the exact date and time of the event. I'd like to go...
When exactly is this taking?...
EDIT: Nevermind, Looks like I'm in! Should be fun...
Old Mar 6, 2008 | 12:10 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
We should ride together for the event. Where you from in the east bay? I want to check out your car sometime
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
kairles
Oct 26, 2015 09:13 PM
gixxer92
Sep 1, 2015 04:32 PM
