got dyno tuned
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
got dyno tuned
guys i have a 88 tpi camaro with a paxton supercharger,58 mm tb,afr 195 74cc heads,ported base stock runners,42 pound injectors,10 inch stall,3.42 gears,1.6 rockers.i was tuned today in fairfield at advance dyno but the guy who tuned it is from the sac area but he came down to tune my car but i have a big problem the numbers are low for what i have 309 rwhp and 369 rwtq.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: got dyno tuned
Have you ever run it at the track, remember the dyno is a tool. What was your numbers before he tuned it?
Re: got dyno tuned
they did not do a base line pull but before with the trickflow heads g1 and stock chip and 24 pound injectors best time on street tires at searspoint was 12.71 at 111mph
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: got dyno tuned
that doesnt really add up. 309whp with boost and heads is pretty low in my opinion. Is that with stock cam tho? could explain some low numbers
Also how much boost is the kit running?
111mph before the tune would be more like 310 whp or so, so if your at 309 now, thats not good for a dyno tune unless its a mustang dyno.
Re: got dyno tuned
about 7 psi and that 111mph was with the trickflows g1 maybe its the 74cc heads and that lowerd my comp a little and the cam is slp 502/510 lift 220/239 dur on a 112 lobe sep and i have 1.6 rockers so the lift is bigger.
Re: got dyno tuned
he use two laptops first one was data logging and the other one he removed my chip and installed adaptor pluged to the other laptop he did adjustments at idle and he had me drive it going fast and slow addind spark/fuel,them we put it on the dyno the first pull was like 280 hp and 300 tq he added more timming he said 27 degree total then the dyno read 309hp 369 tq
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: got dyno tuned
Something is very wrong with your setup. I have more power than that and I dont have a blower.
Re: got dyno tuned
i'm sick right now kevin91 because you don't have a blower and have way more power than me and that was 500 for the tune and 100 for three pulls on the dyno could it be the stock tpi killing my power
Car: '02 Z06
Engine: L33 5.7
Re: got dyno tuned
Does it feel any faster after the chip burning?
Car: 89 Iroc-z
Transmission: TH400
Re: got dyno tuned
it may be a slight mismatch but the blower should make up for it, and STILL make alot more power than that. I know my buddies full bolt on L98 with a procharger at 12psi (I THINK, could have been lower) ran mid 12's at over 112mph i believe it was before blowing up, and thats an estimated 330-350whp. you have heads/cam... so it should still make more power if not the same
Re: got dyno tuned
so if its mismatch what parts am i missing he said that the stock tpi was the problem
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: got dyno tuned
1. Stock TPI. 'Nuff said.
2. Stalled auto, stalls can eat power in a dyno graph but perform at the track/street.
3. Dynos are just tools, their numbers can't be taken too literally. Check with others that have dynoed there to see if it reads low or not. If it was a mustang dyno you could see quite a bit more on a dynojet... and what was the correction factor?
That being said, I think you need to ditch that intake and you'll see an easy 50 more hp. I had a N/A LT1 with ported stockers and a custom cam and it made a touch over 400, you should be able to blow that car away imo..
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: got dyno tuned
Received your PM antoine, but not sure what you wanted, or if you were just telling me your issue.
I'm assuming it's because Mark mentioned me, as he's been helping tune my car for a few years now.
My GTA is not that fast next to other comparable setups, so take my advice with a grain of salt.
I'd say it was all covered in this thread already and by looking at your combo I'd have to agree.
urbanhunter44 said it best with 1-3.
1. You are not maximizing your blower/heads/cam potential with stock runners.
I'm not a Paxton blower fan to start, but it's being choked with the stock TPI.
I have a TPI setup, but it's all aftermarket and worked a bit.
2 & 3. Don't go into a dyno looking for impressive #'s, it rarely happens.
Use it as a tool only and translate it to the track. I haven't dyno'd since the addition of my blower, but I wouldn't be expecting much since I was only netting a 108mph last time out at the track.
Advance dyno uses a Dynojet I believe, so I'm sure that was the best your combo can put out.
The tune helped you considerably with all your mismatches, but it's not magic. It just optimized what you have and probably smoothed your pull throughout the rpm range.
Every car wants something different and it's hard to compare to other setups.
Bummer it cost you $600 for it all, but start with exploring other intakes and go from there.
Re: got dyno tuned
the stall i have is a non lockup 24-2600 stall,whats a good intake to start with stealth ram,tpis bigmouth,lpe super ram etc.
Car: '89 GTA
Re: got dyno tuned
Depends on smog, powerband and your wallet.
Check out the "Alternative Port EFI Intakes" forum.
There is a sticky that gives you info on the many options.
Car: '72 Chevy Nova
Transmission: TH350
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: got dyno tuned
What do you feel about the entire process, start to finish; other than the bad news on the numbers. Can you rate the difference on a 1-10 scale? Would you do it again or do it differently??? I'll be doing dyno tuning sometime later this year, so I is/are curious.
I understand that dynoing an engine while it's out of the car, without any accesories bleeding the power off, no exhaust restrictions, etc and give some very 'fat' numbers. Where do you think you fall into on the percentage of parasitic drag of the horsepower with your current drivetrain; 15% - 25%.
Would you use this shop again? thanks, Nitro
Car: 89 Iroc-z
Transmission: TH400
Re: got dyno tuned
your down 20-30whp without locking up the trans converter. SO theres one reason your numbers are bit low.
Full bolt on TPI setup from runners to afermarket base will definately gain alot of power on that setup. If emissions is NOT a problem, then go HSR and gain even more hp....i mean alot. With that cam and shorter HSR runners, your gonna extend your rpm range near 1000 rpms and thats alot! Your car will definately approach the 400whp mark with intake swap and better tune, and locked converter
Re: got dyno tuned
Re: got dyno tuned
my convertor is a nonlockup one.
Car: 89 Iroc-z
Transmission: TH400
Re: got dyno tuned
with unlocked converters your not transfering all the power the dyno so dont be dissappointed in low dyno numbers. However at the track or on the street, it doesnt matter and the car may even be faster with the converter open. I know my car ran faster 1/4mile times with unlocked converter.
Re: got dyno tuned
Car: 89 Iroc-z
Transmission: TH400
Re: got dyno tuned
run it at the track to see whats up. I think my buddies high stalled 406 chevy put down high 300's whp but ran high 10's at ove 125mph.... so thats some food for thought. in a manual that would be like 500whp
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
Re: got dyno tuned
did u try any more timing did u check see were the timing was under boost and to be honest its going to change once ure at the track and the weather go to a test and tune this coming week im going to the track weds night and ill be there sunday should be there sat my buddies takin his nova only reason i went to a dynos before is for the air fuel reading the rest has been on me dont feel baD i made a 290 to the wheels and i thought the made my car worse i ended up doin it over myself and the had so much timing i went and melted a plug trial and error my dyno is the track i whould of bought tires couple test and tunes or weds nights and got me some lunch whould of been better then 5 or 600
Re: got dyno tuned
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Re: got dyno tuned
if anybody is interested in a sn 2000 paxton cheap i pulled it off today off a buddies car 88 iroc-z 1000
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Re: got dyno tuned
that dyno was over a year and a half atleast my car was going 13.2 13.3 and now same combo 12.50 i got tired of waisting money on dynos ide rather put it to use dial it in myself and beat on it at the track
whats ure base timing and ure total
Last edited by valencia1z; Feb 24, 2008 at 07:45 PM. Reason: Automerged Doublepost
Re: got dyno tuned
before the tune he said to put it at 6 degrees and total in the chip he put it at 27 degrees
Re: got dyno tuned
i have the dyno graph,how do you post it i can email it to someone and they can post it here.
__________________
__________________
Re: got dyno tuned
Here is your dyno graph from saturday, the blue was the first run and the
red was the last run.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: got dyno tuned
Stock intake can produce alot of power under boost, but an aftermarket intake can produce more............
What valve springs do you use?
What is your exhaust setup?
/N.
/N.
Engine: L98 355
Axle/Gears: 3.70
Re: got dyno tuned
Something is wrong, and it's not just his parts.
Before I grenaded my supercharger, I was running a P600b on a COMPETELY STOCK TPI setup with a mild cam and STOCK heads. Also, a totally stock chip, no joke. My compression was lowered to 8:1. at 7psi with the converter _unlocked_ I saw 346 rwhp and 406 rwtq. I also ran a 12.52@111mph in July with track temps of 100 degrees and no water/ice on the intercooler and bald drag radials with a 60ft of 1.9. With his heads, ported base, and a tune, he should be close to 400whp if not over, even with an unlocked converter...maybe a bit less on a mustang dyno.
Either something is seriously amiss in the tune or a/f, the boost gauge is flat out wrong and you've got a major boost leak, or your engine/valvetrain isn't healthy.
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: got dyno tuned
your trickflow head setup was on target at 12.7 111mph. that would have been in the 350rwhp ballpark. what else did you do during the head swap we are unaware of?
Car: 89 Iroc-z
Transmission: TH400
Re: got dyno tuned
if they are the new AFR eliminators, they ahve 1.29 inch ls1 style dual springs, rated at 135lbs at 1.800 installed height. Mine were factory setup at 1.775/ 1.780 intake/exahust so the pressure was higher.
those are pretty stout springs but maybe you could use more valve spring?
Re: got dyno tuned
Re: got dyno tuned
it feels alot faster maybe i should change the cam and put one with a 114 split
Car: '02 Z06
Engine: L33 5.7
Re: got dyno tuned
I dont think valvesprings are an issue, the dyno graphs dont show typical valve float associated with weak springs in my judgment.
Car: 89 Iroc-z
Transmission: TH400
Re: got dyno tuned
the cam looks ok... 112lsa but it has 220-239 duration, a big split there. It should run ok with the blower. Maybe its not a good TPI cam? I know there are some guys having problems with making power on long shapped runner TPI setups and i think it may be a cam issue.
Re: got dyno tuned
found out it was only getting 3.5 pounds of boost maybe belt was slipping
LT1Formula
Oct 8, 2015 08:34 PM
