Northern California Discussion board for Northern and Central California.
Took the Formula to the track.........
Old Mar 19, 2008 | 11:41 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
and it didn't run to well. It ran great up to about 4500rpm then it would start sputter and pop. I cought a glimps of the fuel pressure gauge and it was at 60psi(maybe a little more) I wasn't fast enough to look at the boost gauge. I think the cause is fuel or ignition .
TraviZ thanks for taking the video.
first boosted outing
Old Mar 21, 2008 | 07:44 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: Took the Formula to the track.........
What does not too well mean? Can't tell from the vid your times. Just 1 run?
Old Mar 21, 2008 | 10:58 PM
kairles's Avatar
Engine: 383/LGX
well basically reving it past 4500rpm was a waste of time. the first run was so bad, I didn't see a point in running it again. time was a 15.4@87mph. I already ordered a cable so I can do some data logging, I also need to have my wideband installed.
Old Mar 22, 2008 | 12:45 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Thats why it called test and tune LOL.
Was that last night?
Old Mar 22, 2008 | 05:59 PM
kairles's Avatar
Engine: 383/LGX
no this was wednesday night
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
