Northern California Discussion board for Northern and Central California.
sooo hmmm...
Old Apr 24, 2008 | 12:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
sooo hmmm...
I called EPP yesterday to order a smaller pulley so I could have a hood on my car but he said the 3.5" pulley would overspin my blower. WHAT?
so now what do i do....
Old Apr 24, 2008 | 05:20 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Re: sooo hmmm...
Give the blower to me and get a little paxton that will fit.... LOL
How much clearance do you need?
Jason
Old Apr 24, 2008 | 06:22 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: sooo hmmm...
Can you just notch the hood a little?
or get a set of matched smaller pulleys? crank and blower, that way the rpm is consistent.
Old Apr 24, 2008 | 08:09 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: sooo hmmm...
I say cut up the hood then replace the hole with some kind of custom fiberglass job .
Old Apr 24, 2008 | 08:16 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: sooo hmmm...
I'm not surprised.
That head unit is an entirely different beast.
There's a reason you have that larger pulley and only slightly smaller increments be usable, but not that big of a jump to 3.5".
Old Apr 24, 2008 | 08:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: sooo hmmm...
i did the math and a 3.75" would be ok for the blower. and probably fit under the hood.
and for the hood comments, its fiberglass, nothing to notch lol.
Old Apr 25, 2008 | 02:28 PM
Vash Vega's Avatar
Car: 1990 Iroc Z,2004 Z06 Corvette
Engine: 5.7 L98 tpi/LS6 346 ci
Transmission: 700r4/MN12
Axle/Gears: 10 bolt 3.23/DTE 3.42
Re: sooo hmmm...
why you didn't buy a D-1SC or a P-1SC
Old Apr 25, 2008 | 02:37 PM
TMoNeE's Avatar
Car: 87 Z28
Re: sooo hmmm...
is this even with a cowl?
Old Apr 25, 2008 | 02:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: sooo hmmm...
Cuz I like to go fast.
I have a 2" cowl, but keep in mind the offset the blower sits in conjunction with the engine, it touches the hood on the flat portion next to the cowl. so unless I had one of those jongblowed(sp?) hoods, the size of the cowl is not going to make a differnece.
I'm enquiring on the price for a 3.7" pulley + belt, said it would net me around 18-20psi. but it will clear the hood. It will also spin the blower to a max of 71k rpm.
Old Apr 25, 2008 | 03:25 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Re: sooo hmmm...
What about actually moving the hed unit down a bit? Maybe re-drill the mounting holes in the brackets? Would that be possible, or is the power steering pump in the way?
Jason
Old Apr 25, 2008 | 04:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: sooo hmmm...
Jason
power steering? what power steering? lol
the fender well is in the way :P
Old Apr 25, 2008 | 05:24 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Re: sooo hmmm...
plasma cutter....
Old Apr 25, 2008 | 06:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: sooo hmmm...
oh my goodness i will not chop up my car!
only modding i've done to it was drilling two holes in the firewall for a clean harness install. thats it!
Old Apr 25, 2008 | 06:37 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Re: sooo hmmm...
You could do it and keep all strength and function if done right. I guess "plasma cutter" sounds pretty harsh.... I have seen it done for mounting turbos in 3rd gens... Just a thought..
Jason
Old Apr 27, 2008 | 10:28 PM
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
Re: sooo hmmm...
Any guess on how much boost you will be running? Are we going to be doing a fuel system in the next couple of weeks? My mom also says hi and that she has her rootbeer floats ready for whenever you drag your *** up to my place to help me on my ride.
Old Apr 28, 2008 | 12:43 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: sooo hmmm...
pick my *** up
Old Apr 28, 2008 | 01:58 AM
Wills91RS's Avatar
Car: 02 Chevy Impala
Engine: 3.8L V6
Axle/Gears: FWD
Re: sooo hmmm...
Jason
Lol, come on now. You must not know Travis that well, that's wayyy too much work for him. He likes the easy yet slightly messed up way
Sorry bish, had to say it, been holding my tongue on this thread for days.
Old Apr 28, 2008 | 03:08 AM
JesasaurusRex's Avatar
Re: sooo hmmm...
rookie
Old Apr 28, 2008 | 08:25 PM
Car: '89 GTA
Re: sooo hmmm...
Still have that 3.5" pulley, or does Terrell?
That might be my next step eventually if it's an 8-rib..
Holla.
Old Apr 28, 2008 | 08:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: sooo hmmm...
terrell has it. i only used it for a test fit.
Old Apr 28, 2008 | 10:35 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Re: sooo hmmm...
Could you take the bracket to a machine shop and have them cut it dow and redrill the holes?
92firebirdguy
Sep 1, 2016 07:53 AM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
urbman
Apr 24, 2002 08:15 AM
Willie
Apr 24, 2001 09:18 AM
