Northern California Discussion board for Northern and Central California.
boost junkies, in here.
Old Mar 17, 2009 | 06:37 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ive got the iroc dialed in to the point i am feeling pretty good about it until around 6k. still need to fix that top end and get my wideband ( ) setup properly, but my point of this thread is, when is/was your boost coming in and what rpm did it peak around?
in my log, boost starts kicking in around 3000rpm and by 4900 im already at 7psi. and sweet jesus first gear is so useless from a stoplight, i held first and when that light turned green i eased into the throttle and it was like neutral revving i had to hit second so fast! but the tire smoke behind me led me to believe that wasnt neutral i was in.
if boost is progressive with rpm, then i should be around 14psi at 7k, but we will see.
im just asking for similiar info so i have something to compare to.
Old Mar 17, 2009 | 09:51 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: boost junkies, in here.
0psi at 0 rpm. still working on brackets... lol....
Old Mar 17, 2009 | 10:33 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
first, all us NorCal'ers have different motors, and different superchargers. with that said the answer is gonna be different. when I get on it in the formula it would jump to about 5-psi then climb to 10ish by about 4200rpm.
Old Mar 17, 2009 | 10:58 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
The D-1SC I ran made 3psi at 3200rpm, 6psi at 4500rpm, and 15psi at 7500rpm. The idea of the turbo I'm putting on is that it will make more psi sooner and more in general too.
Old Mar 18, 2009 | 04:08 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I'd have to agree with Terrell's response on the differences, especially with possibly diff. methods in reading the boost pressure.
How is everyone gauging how many psi @ what rpm?
Eyeballin' gauges?
Datalogging with an app. that sees boost?
I would just be going off what my possibly inaccurate factory tach / boost gauge is telling me. Similar as others listed, but with a different step-up-ratio.
I've yet to dyno and see where my actual general peak #'s tap out at, let alone when and for how long boost is really initiated.
Hoping to have some WOT dyno tuning done shortly and get some of this worked out.
Old Mar 18, 2009 | 07:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im using datalogs, duh.
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
and of coarse everyone will be different, thats why i asked, wanna know whats out there.
Old Mar 18, 2009 | 07:26 PM
Car: '89 GTA
Don't worry about what's out there and just figure out why your 1st gear sucks.
. ..or else my TPI will beat you.
Old Mar 18, 2009 | 07:31 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
its the tires, they are noy sticky enough
Old Mar 18, 2009 | 07:38 PM
Car: '89 GTA
Don't you have huge 315 drag radials?
Old Mar 18, 2009 | 09:11 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I would like some 315 drag radials!
My Nitto 555s have lasted a while (I give them that, I've treated them badly) but they can't hook for ****
Old Mar 18, 2009 | 09:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
315 street tires for break in period
Old Mar 19, 2009 | 08:53 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i expect about 15psi in my groccery getter grand prix
Old Mar 22, 2009 | 07:42 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
So true. I can't wait to get rid of mine and get the matching pair of Toyos on the front.
Fanatic1074
Oct 3, 2022 05:57 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
LC2 TECH
Oct 13, 2015 11:53 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wstephan96
Sep 25, 2015 04:28 PM
