March 20, 2010 GTG - BBQ/Swap Meet/Sac Raceway day!
#151
Car: 82 Trans Am, 68 El Co, 84 K5
Engine: Carb 350, Carb 327, 6.2 Diesel
Transmission: Borg-Warner T10, TH-350, 700R4
Axle/Gears: 3.23, stock 10 bolt, 3.73
Re: March 20, 2010 GTG - BBQ/Swap Meet/Sac Raceway day!
so 3rdBird how did the trans brake work out?
im thinkin to put 1 in the el co when i do the big block swap, it would be on a glide. or ill just drop a M22 i got sittin around sittin around.
#152
Car: Black 1989 Formula Firebird
Engine: 5.0 TBI soon to be LT1
Transmission: 700r4 soon to be T56
How much are those tranny breaks anyways... where can i get the bigger housings to use more clutches for the 700r4 btw.
#153
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Honestly, I have no idea where you would find a supplier for a 700r4 trans brake, these valve bodies are usually reserved for the th350/th400/powerglide transmissions.
If someone out there makes it, its going to be a hole in the wall place.
#154
Car: '92 Z03
Engine: LSX
Transmission: M12
I had fun at the meet, sorry I could not stay for long / run my **** because I have been working nights and it has been 7 12's...
You all know I will be there for a mandatory appearance though, sleep or no sleep, nice to see a few new cars and faces. Many thanks to Marc and Joey for hosting and the food!
I happen to think your hot rod is rather awesome there, J
P.S. Where are the rest of the freakin' pics???
#156
eeeesh... I cant wait to get a real Satin BLack finish on my car... I painted that out at starbucks one night... earlyier this week... i only used like 3 cans... thats right Rattle can.. i think at least it makes all the other thirdgens look better.. lmao
#157
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Finally Firebirds out-numbered the Camaros. Very good turnout, thanks to the Bay area guys that made the trek.
As far as adding a transbrake to any transmission.. Its more designed for a drag race application. If you want to see what its like to have a transbrake,
Put your trans in NEUTRAL, rev it up to about 4500 rpms and pull it into drive.
If you dont break something the first or second time you do that..
your car can survive anything.
#158
ya i think ill get 1 for the el camino. its goin to have a stroked and bored 427 bbc that puts it at 496ci. and with the trans brake ill be more consistent on launches. or i can build up the M22? or will the built glide be stronger?
ne how it will wait till the TA got paint and upholstery done. so i got time to plan that project.
#160
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I got some pics also.. will post later this evening.
bigjay89gta
10-15-2015 08:04 AM
