So Iam contemplating taking the a/c out of the car, and just getting the a/c delete pulley and the heater box. The reason is this isnt a daily driver by any means, (but it will be on long trips) and i just painted the engine bay and im trying to make it nice and clean. Just wondering how many of you did the same thing and if your happy with it. I saw Will's iroc and his engine bay is nice and clean looking.
I don't have a Camaro
, but I do have A/C in my GTA. Almost never use it, but it's there!
, but I do have A/C in my GTA. Almost never use it, but it's there!Quote:
Noted !! Sorry I always forget about the TA crowd Originally Posted by OUTATIME GTA
Jk, but I'll prolly get more responses by changing the titleMine has always been in the car... was never charged up..lol. but that will change this summer!
norcalz28
close
I removed mine. If I had it to do over, I'd prolly make some modifications and keep it. On a hot day, I really miss it. Otherwise, it makes working on that side a lot easier without it all in the way
I have had mine for 13 years. I cant remember ever using it. Hmm, now im curious.
I did not have my A/C for the past 5 years after my LS1 swap. Guess what im doing right now, Putting A/C back in it. You cant live in the Valley without A/C. Keep it bro
built91Z28
close
Mines not a daily driver by any means, but it's primary purpose is a street car. With that said, I do not have A/C right now but I am going to put it back in. But keeping with the tradition of the car, it won't be a stock system. I plan on either modifying a ac box or making one and mounting it under the dash. There's not tons of room, but there is enough. I also plan on a polished aluminum compressor with march brackets and braided ac and heater lines. I'll then find a set of switches and ***** that activate the blend door by cable and not vacuum.
i still have a/c. i have thought about taking it out, but its just to hot in the south without it.
I have to have it. Daily driver and I'm a fat boy so I sweat when I see someone wallking haha.
My A/C work damn good and I'm never gonna get rid of it. Best part of it is that the engine doesn't heat up past 185 in the summer. The car still has the stock radiator. Not too bad for a 392whp car with 3.73 gears.
dang you guys!! No help ... hahah thanks for the responses I better start polishing as much as i can
Remember you have a lot of glass where sunlight can really heat up the car. A/C is not always needed, but nice on some days.
The A/C compressor will shut off at wide open throttle so no real loss of power there. Same with power steering pressure, A/C will shut off when taking hard corners.
Couldn't wait to rip that useless 10lbs of **** in a 5lb bag non-working R12 garbage out of my car as soon as I got it
Live in AZ would not own one without AC>> Gotta have one!
Im not worried about robbing any kind of power whats so ever, chances are if I keep it ill use it a few times a year. Just like I do with my daily driver honda civic but that actually robs be of mpg so thats kinda why with the honda. Im more worried about the clunky ness of the whole system and how much i actually use it vs how nice and clean your engine bay looks when your done removing it.Originally Posted by ckelton
Remember you have a lot of glass where sunlight can really heat up the car. A/C is not always needed, but nice on some days. The A/C compressor will shut off at wide open throttle so no real loss of power there. Same with power steering pressure, A/C will shut off when taking hard corners.
I removed my a/c..and heater!
Our car is black and it can get very here in Sac so could not go without AC!
I had to gather parts to put my A/C back in the car. Someone did an engine swap before I got it, although they put in a 305. The a/c works great though, running it on 410a no problems.
Used it twice, been out of the car for years now.
well you got a 4.56 gears and a 4000 stall cartman you dont do that much street or highway driving....or do you?
my car is my DD, with T tops its like a mini microwave without a/c since my dad has his own shop and i know how to work on stuff, i swaped all the o rings, put the r134 fitting on it put some oil in it, pulled it into a vacuume and she held
so i got working a/c for about 20 bucks
so i got working a/c for about 20 bucksSupreme Member
ive seen poeple just change the fittings add some oil and vacuum it. recharge and be fine too
Here in Southern California it does get warm so I keep mine in good operating condition.
norcalz28
close
I keep meaning to buy some t-top shades!
let me know where to get t-top shades, please
just had my tops limo tinted.. and it still gets HOT in Tucson !
Bill
Bill
A bit off topic, but many moons ago I bracket raced a big block 73 Vette. If I was "out" on the other lane at the 800' to a 1000' mark I would flip on the air with the fan on hi to prevent the dreaded breakout but still get the win light!!!
Hey, it was a no box bracket, ya gotta do what you gotta do! About every other Saturday afternoon, one of the tech guys would crawl all over the underdash and underhood area of the car looking for the retard box!!! After I sold the car and moved to Super classes, I told him about the A/C deal----he still hates me.....
KITT1983
close
i have A/C in my KARR and I use it every year
Unless you only want drive in the winter, you need A/C 6 to 7 months of the year here in Texas to survive. I drove an old VW here for a few years and it was miserable from May to October even with the window vents. In a car without window vents like a thirdgen, you would be wet with sweat pretty quickly, the interior would never get much below 100 degrees in the daytime. Not an enjoyable ride.
Quote:
Where you from and how often do you drive it?Originally Posted by EvilCartman
Used it twice, been out of the car for years now. Supreme Member
Quote:
Chico area, the last couple years I haven't driven the car much but used to be my only car. Temps range from 30's-40's in winter to 100+ in the summer.Originally Posted by dspencer24
Where you from and how often do you drive it? Quote:
Don't forget, my car hasn't always been like it is now, it used to be my daily driver. About a year after I got it back on the road from buying it, out came the A/C and just ran a heater. It just didn't seem to work that great even when fully charged so I just ended up driving around with the windows down.Originally Posted by UnderCover89TBI
well you got a 4.56 gears and a 4000 stall cartman you dont do that much street or highway driving....or do you? Take a look at an after market pump like Vintage Air. Finding a nice polished pump to replaced the stock one will give the best of both worlds.
Quote:
I gotcha. I did not know the whole history of your car. Cool stuff. Mine works good enough to have it! I'd love to not have to have it!Originally Posted by EvilCartman
Don't forget, my car hasn't always been like it is now, it used to be my daily driver. About a year after I got it back on the road from buying it, out came the A/C and just ran a heater. It just didn't seem to work that great even when fully charged so I just ended up driving around with the windows down. Junior Member
I know, just the heat from the motor and trans (when it was an automatic still). Going to the drive ins, I would open the hood for an hour before the movies started to let as much heat out as possible because the car just gets hot.
KITT1983
close
Quote:
you are lucky that you guys still have drive ins Originally Posted by Devolont
yeah I know that problem
The drive ins are amazing.
It is a bummer that there are not more around because it is a great place for people like us to meet but there are not a lot of third gens out and about.
I have had my a/c on every day so far just to keep the air on the cool side
closest drive in i know of near me is in rancho cordova over an hour away....blah!
KITT1983
close
Quote:
are there any indians at the drive in?Originally Posted by UnderCover89TBI
closest drive in i know of near me is in rancho cordova over an hour away....blah! Junior Member
I usually ride with the ttops down along with the windows don't really see the need for a/c unless its really hot and raining..
Which never happens in bama
Oh yeah we got a couple of drive-ins here in AL I just so happen to live right down the road from one.... too bad my stereo doesn't work.
haha. the drive ins here is only a 10 minute drive from my house. I have a nice sound system in mine. A custom sub box that I built to fix the entire trunk. nice 6x9s and then the crappy 4x6 in the dash. I also installed 6inch rounds in the doors.
KITT1983
close
the Weirs Beach Drive-In Theater is about a 2 hour drive
