anyone in the BAY willing to help ?
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
I'm asking if anyone willing to help me ( have money and beer ) for some reason I have a problem putting my distributor in tdc. before I used to get it close to number 1 and it will work fine . now that I'm using as a cam sensor I can't do that no more, my dilemma is my distributor does not seet down properly when in the correct location. I live in oakland by the airport.please help me I want my car to run thanks mark
Car: '82 Z28
Re: anyone in the BAY willing to help ?
Couple ways you can go about it. Take a long screwdriver and turn the oil pump shaft so the distributor can set down all the way or drop the distributor in and bump the starter till it drops all the way. I've done both plenty of times without problem.
Car: 92 RS
I will try again tomorrow ...... but something is extremely wrong I have put distributers in and never had issues like this. how much play is the oil pump supposed to have? I think something is stretched or broken down there.
Car: 1969 SS Camaro, or 1990 Iroc vert,
Engine: 350 and 305
Transmission: tb350 and 700r4
what he said...no biggie just rotate it so it lines up with the male slot on the Dist shaft...works for me...good luck
Car: 92 RS
Thanks I'll take all the luck I can ....... is just frustrating me here at work thinking about it .....till tomorrow
Car: '82 Z28
Just think of it as the distributor being a big flat blade screwdriver and the oil pump shaft being the screw. You gotta get one to line up with the other before things work correctly
I've fought and fought with it sometimes and other times everything goes in scary smooth.
I've fought and fought with it sometimes and other times everything goes in scary smooth. Thread Starter
Car: 92 RS
I got my distributor in , took bout 45 min . so now I'm taking it to the tuner thursday @ Newtech with Nick . Finally !
