Need to borrow a MAF.......
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I think my mass air went bad, when its plugged in, car runs like a$$. When I unplug it, it runs like a dream. If anyone is willing to lend me theirs for a couple days, I would be very appreciative.
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: Need to borrow a MAF.......
I think I have one. Been sitting for a while, but was working when I pulled it off.
Engine: gone
Transmission: gone
Axle/Gears: gone
So did you get one? im anxious to see your car in action again John it's been awhile!
Im gonna go get Terrells when I get back hm and test it. Will have a better idea this wknd.
Update... swapping MAFs did not cure the idling problem. After tearing down the car once more to ohm injectors and test egr (SR too big to get my hands underneath it), I began looking at other things. I found that my MAF Burnoff relay was being controlled by a MAF Power relay
But still worked before. I then went down to fuse panel and found the fuse that controls the domelight, hatch pull down, glove comp light, cig lighter etc. was blown. That same fuse also sends power to the Computer Command Control. Popped in a new fuse, blew instantly... traced the short to a bolt in the cig lighter. Removed bolt, changed fuse again, fired car... now he idles by himself. Im hoping my tuner can take some of the richness and surging out of the motor tho. But its almost done.
But still worked before. I then went down to fuse panel and found the fuse that controls the domelight, hatch pull down, glove comp light, cig lighter etc. was blown. That same fuse also sends power to the Computer Command Control. Popped in a new fuse, blew instantly... traced the short to a bolt in the cig lighter. Removed bolt, changed fuse again, fired car... now he idles by himself. Im hoping my tuner can take some of the richness and surging out of the motor tho. But its almost done. Supreme Member
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh sweet. Man good working chasing down the short, so she might be ready to make some runs late this month then huh?
Slim chance... But a chance nonetheless. I'm currently on open headers. If I get a trailer it would be an untuned run. We will see.
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh no point in running it if not tuned because you know its not running to its best. Get her tuned, get her exhaust and git er done!
