Northern California Discussion board for Northern and Central California.
Side project
Old Oct 24, 2011 | 10:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Side project
While I am still putting the motor back together I finally got around to getting this done. I dont think I need to explain what it is. If your not sure, take a guess.
On the topic of my blown headgasket, after removing the heads I decided to pull all the pistons due to obvious signs of detonation. I had scuffs on my cylinder walls and piston skirts. Everything has been cleaned up now. I honed my engine block to get fresh cross hatches in it. New piston rings will be here tomorrow and assembly begins. between work and school I have had not much time to work on this so it has been only a few hours at a time. This new mod will prevent future detonation at least!
Old Oct 24, 2011 | 11:08 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Side project
TWIN 7GPM!!!
Old Oct 24, 2011 | 11:44 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Side project
so im lost. your adding more fuel to it some way or what? or water injection? i dont know about these cool ways to make power these days...lol
Old Oct 25, 2011 | 12:09 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Side project
TBI guys aren't worried about "power"
Old Oct 25, 2011 | 12:46 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: Side project
about time
Old Oct 25, 2011 | 02:36 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: Side project
You got it on second guess.
It is a 50/50 mix water/meth.
increase octane.
Decrease combustion temperatures.
Overall better for the engine and because of these two reasons, increases power as a side effect.
No more detonation
Old Oct 25, 2011 | 09:39 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: Side project
How much was the kit?
I forget, but why didn't you just add a custom intercooler to reduce your detonation? Cost? Efficiency?
Old Oct 25, 2011 | 11:05 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Side project
damn skippy!
increase octane.
No more detonation
Oh okay...I heard water injection is hard on the rings and can cause them to crack/split/break also?
Old Oct 25, 2011 | 11:23 AM
Car: '89 GTA
Re: Side project
Hopefully it's a proper setup with failsafe/monitoring features and that your magical tuning equipment can account for it.
I was always curious if you tune for it and your pump fails, or runs dry, then what happens? Unhappy pistons? haha. I'm sure there is a warning though.
Old Oct 25, 2011 | 11:25 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: Side project
I pretty much summed it up in the first post. It can provide even colder intake temps then an intercooler. It weighs less and the meth gives an octane boost.
damn skippy!
I have not heard that. Maybe in diesel applications. I will be running 50/50 so I doubt it.
Old Oct 31, 2011 | 01:10 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Side project
A big red light comes on!
Old Oct 31, 2011 | 10:28 AM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: Side project
Hahaha Vin... Classic
Old Nov 1, 2011 | 04:57 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: Side project
I never saw this post, but ill reply to it now.
You don't really tune for it, it is a detonation suppressor. If it stopped functioning for any reason then the knock sensor would pick up the detonation and pull back the timing and you would lose the power. It isnt anything extreme like nitrous, but on average, dyno results suggest an average of 5-10% hp gain.
Old Nov 2, 2011 | 12:14 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Side project
5-10 percent? dang 10 percent of 500 hp is 50 hp, 50 hp is worth a few tenths...dang trav your going to be running a 10.7 in no time!
Old Nov 2, 2011 | 02:00 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Side project
What kit is it [ QUOTE=TraviZ;5076937]While I am still putting the motor back together I finally got around to getting this done. I dont think I need to explain what it is. If your not sure, take a guess.
On the topic of my blown headgasket, after removing the heads I decided to pull all the pistons due to obvious signs of detonation. I had scuffs on my cylinder walls and piston skirts. Everything has been cleaned up now. I honed my engine block to get fresh cross hatches in it. New piston rings will be here tomorrow and assembly begins. between work and school I have had not much time to work on this so it has been only a few hours at a time. This new mod will prevent future detonation at least![/QU
Old Nov 2, 2011 | 03:09 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: Side project
devilsown
pwdbychevy
Apr 16, 2023 07:27 AM
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
g.l.mos
Aug 22, 2015 12:02 AM
