Northern California Discussion board for Northern and Central California.
WTB: 2.77 axle. disc brakes
Old Nov 22, 2011 | 07:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Anyone have a lead on a 2.77 with disc brakes? I need to make a long road trip to L.A. for the next run to the coast event sponsored by pro-touring.com and my poor th400 won't be kind to my gas mileage with the 3.42's.
I have a 3.42 ten bolt to trade or cash of coarse..
Old Nov 22, 2011 | 09:04 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: WTB: 2.77 axle. disc brakes
My ears and eyes are now open for 2.77 rear end for Mr. Jackson
Old Nov 22, 2011 | 09:35 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
eh throw in the ten bolt 2.73's as well. probably a bit more common to find, as long as it has discs
Old Nov 22, 2011 | 10:38 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Start saving. Man up and drive slow.
Old Nov 22, 2011 | 11:04 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
So if I find a drum 2.73 you dont wanna swap your brakes onto it???
Old Nov 23, 2011 | 12:29 AM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
I can check my 86 Roc and get back to you. It's got the stock rear in it. Is your rear a 4th gen or no?
Old Nov 24, 2011 | 02:39 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
no cuz i dont want to pull axles to put on backing plates just for a weekend getaway. When I get back into town I want to swap my 3.42 axle back in. I just want the 2.xx for out of town cruises, so I want an easily swapable rear end.
the axle in my thirdgen is a thirdgen axle, the wheels on it are correct offset. The 3.42 axle I have not in my car is a fourth gen rear end.
Old Nov 24, 2011 | 07:24 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh okay Traviz. I'll keep an eye out for what you want. You want a known good rear end or you okay with a junkyard rearend? can pull the cover off and make sure all is good?
Old Nov 25, 2011 | 01:26 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
junkyards are fine
Old Nov 25, 2011 | 02:24 AM
Axle/Gears: 4.10
I'll check my rear on my 86 tomorrow and I'll let you know. Does anyone know which RPO code is for the 2.77 gears?
Old Nov 25, 2011 | 01:48 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
This ^ seems more logical.
Is the gas savings that much better from a 3.42 to a 2.77 or equivalent for this to even be worthwhile? I can see maybe if you had 3.73s or worse.
Old Nov 25, 2011 | 01:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
big difference. I went from 2.73 to 3.42's and that was with overdrive. w/o overdrive a lot of rpms for his engine and supercharger
Old Nov 25, 2011 | 02:30 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
it will be like a 700rpm difference yes its a big deal especially on a 400mile road trip.
Anyone else here in an L.A. Cruise for a weekend? its a really big deal.
Old Nov 25, 2011 | 02:35 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
when is that next event?
Old Dec 30, 2011 | 05:59 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
http://modesto.craigslist.org/pts/2775090112.html
i dunno what the gearing is. you can contact them.
Old Dec 30, 2011 | 06:10 PM
Car: '89 GTA
Could be 3.08, 3.27 or a rare 3.45.
Old Dec 30, 2011 | 06:17 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Rare? that sounds expensive!
Old Dec 30, 2011 | 06:30 PM
Car: '89 GTA
Well, the G92 option on the 305/manual if you consider that rare.
'87 GTA 305's were the standard 3.08, autos the 3.27.
Pretty sure Travis wants 2.77/2.73 for it to be worthwhile.
Old Dec 30, 2011 | 06:44 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah i know. i didnt know the gearing i just posted it up so he could find out. if he cant use it oh well!
Old Dec 30, 2011 | 06:48 PM
Car: '89 GTA
Always lookin' out for others.
Old Dec 30, 2011 | 07:00 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
so not appreciated around here...!
Old Dec 30, 2011 | 07:55 PM
Car: '89 GTA
You'll get used to it, haa.
Old Dec 30, 2011 | 08:31 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thanks for keeping your eyes peeled. not a good lead, but im still looking!
Old Dec 30, 2011 | 11:25 PM
lemons racer's Avatar
Car: 86 Camaro, IROC springs & bars
Engine: Mild 350,Q-jet,headers
Transmission: M-21, 12#flywheel
Axle/Gears: 98 7.5, 3.73 torsen.
I've got a 3.23 large disc rear out of a 90 Firebird Formula that we ran in the 24hrs of LeMons. I know its not exactly what your looking for, but I live in Grizzly Flats, only about 55 minutes from you. Another option might be to just change gears & probably the carrier, keep all the shims with each unit & you could swap them out in an afternoon, not as easy as a 9" but no big deal. I don't get on the computer on a regular basis so if your interested just call Gregg at 642-9563.
Old Jan 6, 2012 | 07:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
found me a 3.08 posi thanks to a local member. thanks all!
Old Jan 7, 2012 | 09:31 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
2.77 would be better.
Old Jan 8, 2012 | 12:07 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
2.77 will still be had if found.
Old Jan 8, 2012 | 01:32 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I've got one. My iroc came with 2.77's and I swapped in a 3.27 rearend years back, still have the 2.77 rearend minus brakes though. Not sure if it's of any use to you. It's in good shape.
Will
Old Jan 8, 2012 | 04:12 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
if his 3.08 has brakes on it that'd work out great Will...huh trav?
Old Jan 8, 2012 | 05:36 PM
norcalz28's Avatar
It's a 9 bolt, out of an 89 so it would accept the PBR backing plates or any others I would think
Old Jan 8, 2012 | 07:20 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah he doesnt wanna have to swap backing plates so im sur ethat'd work for him. get it traviz!
Old Jan 9, 2012 | 02:04 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
very nice how much?
Old Jan 12, 2012 | 01:58 PM
norcalz28's Avatar
100 bucks? It's got about 90k miles on it, solid rearend. Axles are in very nice shape, had everything apart to inspect it. 2 covers, rear springs if you want them.
Old Jan 17, 2012 | 09:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
damn how am i not getting these notices on replies.
I will take it.
pm sent.
Old Jan 17, 2012 | 11:17 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
i already bought it. its 200 bucks now but its 25 mins closer to get soo...haha.
Old Jan 17, 2012 | 11:22 PM
J-(Chicago)'s Avatar
Car: 85 88
Engine: 455 Olds
Transmission: TH350
Do the 9 bolt and the 8.5 have the same length pinion snout?
I would think swapping an entirely different housing would mess with the driveshaft length.
Hopefully I learn something today.
Old Jan 17, 2012 | 11:45 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well the easiest way for me to answer is. all third gen's use the same length driveline, manual, automatic etc. so the differentials are fine to use with whatever drive line you have.
Old Jan 18, 2012 | 12:25 AM
Car: 85 88
Engine: 455 Olds
Transmission: TH350
Wow, that's wild. Gm should have done that from the get-go. When I swapped my 7.5" for an 8.5, I had to use a 1" shorter driveshaft approximately.
Old Jan 18, 2012 | 10:39 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
wait, srs?
Old Jan 18, 2012 | 11:01 AM
norcalz28's Avatar
I PM'd you Travis. It's yours if you still want it.
Will
Old Jan 18, 2012 | 11:21 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Originally Posted by TraviZ
wait, srs?
just teasin you bro....
Old Jan 18, 2012 | 11:22 AM
  #42
Engine: gone
Transmission: gone
Axle/Gears: gone
well the 8.5 is the 9 bolt? everything ive read or seen says you can use the same driveline in any auto/standard thirdgen. if I am wrong i would like someone to correct me so I do not give out misinformation.
Old Jan 18, 2012 | 11:30 AM
  #43
norcalz28's Avatar
As far as I know it should work. Hell people put 4th gen driveshafts and rearends in with no issue.
Old Jan 18, 2012 | 11:49 AM
  #44
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah i meant to say 4th gens too for that matter.
Old Jan 18, 2012 | 12:20 PM
  #45
kairles's Avatar
Engine: 383/LGX
8.5 is GM's other 10 bolt, used in just about every other RWD cars and trucks.
Old Jan 18, 2012 | 01:28 PM
  #46
Engine: gone
Transmission: gone
Axle/Gears: gone
ah okay thanks for the info. buddy. I could see a whole different design rear end being different for the driveline sure.
Old Jun 7, 2012 | 05:24 PM
  #47
norcalz28's Avatar
Dunno if ya got that rear end yet, but this one looks to be pretty solid.
http://sfbay.craigslist.org/sby/pts/3051526010.html
Old Jun 7, 2012 | 09:59 PM
  #48
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I JUST stripped my 2.77 ring gear and pinion out of my 9 bolt in favor of a 3.27. Wish I could help. Sorry bud. Ill keep an eye out tho.
Old Jun 7, 2012 | 10:00 PM
  #49
Copchaser's Avatar
7.75 is the 9 bolt
Numbah-1
Sep 12, 2015 08:57 PM
drb930
Sep 9, 2015 10:53 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
rudolphschenker
Sep 4, 2015 02:41 AM
