Sig for xpndbl
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Sig for xpndbl
Try this on!Try this on for size.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
thanks andre
that looks great.
Steve
PS I had andy uppload my sig pic the first time, how do I change it to that picture??
that looks great.
Steve
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Axle/Gears: Posi
Steve, glad you like
Anyone else wanting one let me know. The better the pics the better the sig.
If you are having problems loading it just follow Andy's directions and put it in place of your old sig in your personal file under usercp. If you are having trouble hosting just put it (the sig) as one of your reader's rides, then post that address in your usercp.
Still need more pics for the calender. Start sending them.
Car: 1989 IROC-Z
Engine: 383 stroker
Re: Steve, glad you like
Axle/Gears: Posi
Your in. I'll go to your site and pull one. Probably that one in your drive way from the drivers side.
Did you ever hook up with Steve?
Car: 1984 Z28
ok,
now i uploaded that sig pic into my reader's rides. Now what would I put in my sig in user cp to allow me to show it?
Steve
Steve
Axle/Gears: Posi
In reader rides right click your mouse on your pic of the sig. and go to properties, highlight the address(You may also just right it down and retype it later in the procedure) and once again right click the mouse. Copy the address. Go back to user cp and where your old sig is paste(or type in) in the new sig and take out the old one. Submit the changes. Once this is done you should be up and running.
Axle/Gears: Posi
Great, Steve. Say that 1984 is not suspose to be blurry. I am gonna redo it and I want you to put the new one in place of the current one. Did you try to scan it in or something. I have never seen them go blurry like that? See the one in my original post how clear it is. Try to resave it again(be sure to use a different address or it won't work) in readers rides. I usually just add a number behind the original address. then dump it in where the original one is in usercp If this doesn't work or you like it as it is(it does kinda look like it's movin fast) I'll leave it. Or I'll change it if you want. Hmmmm. Interesting.
Car: 1984 Z28
yea andre,
i noticed it's blurry. Well I rescanned it again and no luck. Who knows, any chance you can put a different background on there? I like the way your flag looks, have any other backgrounds?
Steve
Steve
pwdbychevy
Apr 16, 2023 07:27 AM
