NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Want a welder for floorboard replacement
Old Mar 12, 2003 | 06:34 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Anyone know a good welder so I can finally replace a rotted floor board before the gathering? Starting to look like Fred Flinstone's car. I want quality work so I'll go wherever but of course southside is prefered or Indiana. Thanks
Old Mar 12, 2003 | 12:40 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Andre,
how have you been? haven't heard from you in a LONG time.
Hey can you give me the number of that guy who sold you your sub box for the back of your camaro for $50. I remember you telling me about that I don't remember the name of the guys shop...I am looking to pick one up really soon. So shoot me a number
Steve
PS How's your car going? Ever replace that motor?
Old Mar 14, 2003 | 11:38 PM
Axle/Gears: Posi
Steve check your pmail. I been real busy this winter and the emmission boys have been hassling me. Just got them straight today. But do you know a welder? I need to fix my floor.
Old Mar 17, 2003 | 06:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Andre,
as for welding I would check out White's and ask them....they usually have someone working there that could do it for you.
I just finished putting together that 305 finally, just need to set the valves and put on a new intake I bought. It now is complete regasketed, new oil pump, welded pickup, crane cam, new valve springs, valves checked, new valve seals intake and exhaust, and the heads were cleaned up. Should be around 280 HP when put together. Should be lots of fun. I have a LOT more $$$ into it than I thought I would have put into it.
Not to mention that I've completely torn into my camaro and am adding a non-a/c box....actually will have heat, running 1/2 inch fuel line, new pump and regulator, and a LOAD of more mods. Should be great at denny's will have true duals by them as well.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
