-=up date on car=-
Guest
Posts: n/a
-=up date on car=-
well i can't take it any more.... i'm ripping apart the block in my drive way. screw takeing it to the shop i want it fix now hopefuly tonight...
i just got done takeing off the intake and i don't see any sign of a blow intake gasket
going to take off the heads now. wish me luck
i want to show up to 3.8TransAm party in my car damnit!
Originally posted by My86Firebird
PROBLEM FOUND!!!!!! its a blown Head Gasket! going to try and get uit fixed tomorrow and show up to the party!!!
I knew it'd be that or a cracked head. Moderator
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Will he make it?
Will he be there?
What will happen at the dastardly party?
Can he fix it in time?
Tune in to the same bat channel on the same server and find out true believer
LAter
JEremy
PS im gonna rag u so bad if u cant get a carbed car back together in time :-P
lol
Will he be there?
LAter
JEremy
lol
Guest
Posts: n/a
U know u would get thigns done alot quicker if u werent online looking at **** and where actually working on the car lol
:-P
lol
Later
Jeremy
:-P
lol
Later
Jeremy
Guest
Posts: n/a
HEy Jeremy
Hey how do i set the lash on the vavles? i'm worried about it cuz i have a score mark on my HEI system so i know where to put it back into place so i don't mess up the timeing.... shoud i ptut he heads on and the intake and the HEI then put the push rods in tighten them down and then "Bump" the motor over and tighten then again then start the motor (howing it will start) and then tighten then down till i here then stop taping and then do a half turn?
HELP ASAP!!
PS if i get there on time i will do the cooking. :-D
HELP ASAP!!
Start at number one cyl and work your way thru
if your confused do number one intake then number one exhaust
just roll the motor over till u see the pushrod move then adjust accordingly
then proceed to do cyl 2 and so on
then repeat for all cyl and recheck.........should also be outlined in any haynes/chilton or factory manual as well
LAter
Jeremy
PS doing it one cyl at a time is alot of turning the motor but u wont get confused either so just go slow and be careful
LAter
Jeremy
U do it the same way as the motor was fresh
aint no difference
just do a cyl at a time so u dont screw up
doesnt matter as long as u do them all
put a socket and a rathcet on the crank with the plugs out and set it normally
aint no difference
dopplar radar is clear for most of chicasgo with chance of scattered showers, should still be able to swim today and get cruising in t-nite
so quit whining about a lil rain :-)
later
Jeremy
Is it running?
later
Jeremy
Is it running?
Guest
Posts: n/a
it was at 7:00am today... i'm just about to bolt on the intake and set the lash on the vavles. just have to torque down the passager side head then put the intake on. run it (open heads for 15 mins) then retorque bolt on the headers and i'm good to go. so if i make it i'm going to be late getting there.
Guest
Posts: n/a
WooHoooo i got the pully back on befor the rain started... all i ahve to do now is retoque the heads and put the headers back on :-D
PS this is the first time i have ever ripped apart a block and put it back together and it still ran!!! :-D -=jumps for joy=-
i now think i can really build my own motor now.
Linson
Aug 21, 2015 02:12 PM
