getting closer
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
getting closer
well new manifold is on dist. is back in, pass. side valve cover back on. most smog equipment back on. gonna drop the fuel rails, injectors, and runners on tommorrow, also change the cables. still waiting on the integrator harness and knock sensor to show up. we will see if I can have this thing running by thurs. night for the crete cruise in. gotta do somethings about the fuel lines though. the extension pieces I have to go from the fuel rails to the flex hoses came out of an 85 car where the alt. was on the other side. so not sure how I am going to hook up the lines. could I use a braded racing line and if so where can I get these in the lengths I need? I don't have the tools to put fittings on the ends of hoses so need them cut for me. any ideas where I can get these? oh and one more thing. I couldn't find a good place to mount the coil and the back of the manifold as I don't have the same bracket to mount it so I used one of the mounting bolts for the wiper motor. works great there. never really know it doesn't belong there.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Looking good :-)
Move that coil back to where it should sit, kinda strange and out of place looking there, when u get a chance :-)
Good work so far
later
Jeremy
Good work so far
later
Jeremy
Moderator/TGO Supporter
Car: 1997 Z28
I am not trying to speak for him. But i think i saw the accel intake base and runners for around 600 new.
got it for 300 something off ebay. but now I have a new possble problem. so all you tpi guys check out this thread on the tpi board. people there just don't like to answer my questions. https://www.thirdgen.org/techbb2/sho...hreadid=253313
I should say the same about your project. body work is something that I am afraid of. where in glenwood are you. used to live in homewood just a little off center ave.
Car: 85z28,
I;m right by gabes rest. down the street from the copers. Ahhhhhh body work is easy if there a dent make it stright. Not much figureing out in that.
theshackle
Aug 31, 2015 10:47 AM
