NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
SD swap.
Old May 23, 2006 | 07:24 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
SD swap.
To swap to SD from my 85 MAF all I need is a SD harness ECM, prom, Relays and MAP right? Do I need to convert to electronic speed sensor ? How would that work even if I had to?
Old May 23, 2006 | 07:30 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
uggghhhh
It should have been fine just repinning? Are u 100% triple sure you just didnt do something stupid? Its what I usually do when something is screwing me?
If you are creative u can do it either way, the code has a bit for mech/optical vss. trick is making it show up as either/or. Has to be set up the correct for one or the other.
Going straight to speed sensor(at trans) would be more or less easiest.
later
Jeremy
Old May 23, 2006 | 07:41 AM
I tried repinning to the newer MAF and no go. The car is not near me and i have to make a day of it every time I actually make any time to work on it and I am just plain sick of messing with this stupid wiring! It is beyond my ability to do with the limited time I have. I would love to fix the harness i have but, I just dont see that happening. For all I know I fried 2 165 ecms before i had it all wired correctly and now it wont work. I really dont wana spend tons of money, but at this point im not sure i have many other options. I am wishing now that I just left it how it was.
I have another electronic speed sensor lying around... but isnt my speedo mechanical? how will my speedo itself work without a cable? Or does the cable go to a sender that sends an electronic signal to the speedo?
Last edited by SMURFN' Z28; May 23, 2006 at 07:44 AM. Reason: Automerged Doublepost
Old May 23, 2006 | 08:41 AM
3.8TransAM's Avatar
Could make it real easy and cheat :-)
9c1 cop cars had a cable/electric all in one speedo sensor on the trans :-)
And yes it goes to a driver in the inst cluster, remember cruise still needs signal from somewhere
later
Jeremy
Old May 23, 2006 | 04:10 PM
when my car was on jenny craig she lost her cruise control Its also a T5 car if that matters. Why exactly does the ECM need to know my speed?
Old May 23, 2006 | 04:22 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
hye im doing a speed desity install as well .. might be able to help you if you have a problem... doign motor swap as well.. but still ..
Old May 29, 2006 | 08:15 AM
ok, I managed to score a complete SD harness and ECM froma guy on e-bay for 100 bucks! All I need to do is plug it in, get a MAP sensor and wire in a resistor so i can use the knock sensor I already have right? I know that I should also deal with those speedo issues, but i want to try and get it running 1st.
Old May 30, 2006 | 02:58 PM
3.8TransAM's Avatar
Good deal.
It will run without the VSS, but for proper operation and tuning you will need to get it hooked up.
Can purge, EGR, and ICa functions all use VSS as well as a few other things.
Give me call if u need more info.
If u need my number PM me.
later
Jeremy
Old Jun 1, 2006 | 07:21 AM
What about my distributer? I still have the 85' stocker in there. Are the connectors the same? Or will I have to switch to remote coil?
Old Jun 1, 2006 | 07:44 AM
3.8TransAM's Avatar
Easiest is to swap out for small cap and remote coil.
U can make an adapter harness to go from one to the other.
I've never had to, but it only involves a couple of wires. Painless harnesses and the like come with the adapter to use either distrib.
later
Jeremy
Old Jun 1, 2006 | 09:25 AM
i have an extra distibutor (remote coil).. so that should make it ezier
$750 L98
Feb 1, 2025 02:25 PM
rubblerubble
Mar 13, 2016 06:57 PM
usafirebird
Sep 29, 2015 11:58 PM
86White_T/A305
Sep 21, 2015 05:28 PM
el_muerte
Sep 16, 2015 12:01 AM
