NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Why did I do this at the beginning of spring?
Old 03-22-2008, 08:42 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
Got the auto trans out tonight along with the console removed stock auto shifter and kick panel. Had to cut the exhaust since hitting with a BFH didnt do anything, spohn guy said my spohn adjustable torque arm will work I still don't see how? If the torque arm doesnt work I'll have to try and find a stock t56 mounting bracket to use my factory stamped one. Also noticed a hole from some object in my drivers side floor pan, not sure what the hell it could have been?
My mess of tonight, everything was disconnected just got hung up on something and started pouring out.
Old 03-22-2008, 10:21 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Why did I do this at the beginning of spring?
Hell, if that's the only problem you've had so far, you're doing great. Besides, at least ATF doesn't reek like gear lube.
Old 03-22-2008, 11:33 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Looks like a crime scene.
Old 03-23-2008, 12:02 AM
novadk13's Avatar
so far no big problems, half a bag of kitty litter hopefully soaks it up for later this week. doing all the ground work first then the interior stuff, my biggest fear will be cutting a hole in the floor
Old 03-23-2008, 12:59 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
nah cutting a hole isn't a big deal at all...and to think I patched the 5 speed hole in my car
Old 03-23-2008, 01:13 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Dave, after you lay out where the hole you're cutting will be, drill the 4 corners before you start cutting with the cutoff wheel or grinder. This will reduce the likely hood it will crack/tear at the corners.
My first car with no SFCs started to have that problem because I just buzzed it with the wheel.
Old 03-23-2008, 12:09 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Run GM or Pennzoil SyncroMesh in that trans, Dave....its TONS better than the Mobil 1 Synthetic ATF I was running before.
Also, when you find out about that torque arm, let me know if you need a stock T-56 bracket, I just might have mine laying around...not sure though.
Old 03-26-2008, 08:01 PM
novadk13's Avatar
got the flywheel back from being resurfaced cleaned the rest of the trans fluid off the floor, installed said flywheel, clutch and pressure plate, removed old auto cooling lines and got more fluid on the floor. Tried to install the t56 and god damn its a heavy trans the T-5 I briefly had was a lot less than the 6 speed, need to go out and get a trans jack since it fell of the 2 jacks twice before I gave up. Didnt cut the hole out but measured the shifter opening to 20-27 inches the 20 being right on the 2 factory dimples on the trans tunnel so I just need to cut 7inch back from there. So we'll see hopefully know someone I can borrow a jack from, or I'll prob have to buy one.
Old 03-26-2008, 09:33 PM
nape's Avatar
I usually lift the trans up until I can get underneath it and put it on my chest, then move it into place. With that said, I have a T5, so YMMV. The easiest way is to get a buddy to help you. Even if they aren't a gearhead, you just need them for the muscle anyway
The trans should slide into place, if it doesn't want to go, have it in gear and rotate the driveshaft until it catches and goes all the way in. DO NOT DRAW THE TRANS IN WITH THE BELL HOUSING BOLTS.
Good luck dude, it sounds like you're moving along so far.
Old 03-26-2008, 10:02 PM
novadk13's Avatar
I know never draw in the trans with the bolts, bad news will happen hopefully this weekend have it back on the ground for the interior stuff and rest of the wiring
Old 04-03-2008, 08:52 PM
novadk13's Avatar
removed and marked the hole for the clutch hydraulic stuff hopefully works out ok, just need to get a hole cutting bit the right size.
brake booster out of the way, where oh where to mark the hole?
Bam! guy I bought the T5 from gave me the firewall template from the original donor car, but still hope it works out alright
Old 06-01-2008, 08:22 PM
novadk13's Avatar
almost done, went through the gears on the jackstands seams like its fine. Only things are I have to make sure the speedo works so I'll have to follow someone, and some peope have had problems with the 3rd gen pedals with the t-56 might have to get a set from a 4th gen.
new hydraulics
still a mess, B&M shifter is very nice
the shifter plate the cost me $142 bucks, I had to cut the holes for the power windows and mirrors, nervous to say the least also got the 6 speed shift pattern insert
Old 06-02-2008, 06:12 PM
RockinGTA89's Avatar
Car: 1989 GTA Trans sold :(
Engine: 350 TPI L98 (B2L)
Transmission: TH700 R-4
dood! man it's looking sweet so far!...wish my car was a stick...however i'm not gonna do that a my gta...but you a da man!
Old 06-02-2008, 08:53 PM
novadk13's Avatar
Went for a spin, man its a blast even with the lame LO3 only thing now Im putting the reverse lockout back in (two more wires)
Old 06-02-2008, 11:31 PM
nape's Avatar
Looks good, Dave! Wait until you get some HP under the hood and you'll really feel like it's a rocket ship.
My car went to the dyno last weekend. 311RWHP and 317RWTQ and it's not even broken in yet. Feels like a rocket ship.
Not bad for a little 305 with unported 'vette AL heads, Performer RPM intake and a Holley 600 carb.
Going racing this weekend. I'll write it up when I get back.
Old 06-03-2008, 04:04 PM
novadk13's Avatar
not bad for a 305, personally im not going to bother with the LO3 going to get some kind of stroker motor eventually.
ZZ3Astro
08-13-2019 12:57 AM
92projectcamaro
12-08-2015 12:25 AM
92rsvortec350
19
10-09-2015 09:39 AM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: Why did I do this at the beginning of spring?
