Thirdgen Fest '08 NEED HELP WITH DOORS!
Subscribe
Mar 13, 2008 | 04:38 PM
Hi all...looks like Thirgen Fest '08 will be packed this year!
I have purchased new doors for my 1986 Camaro Berlinetta from Denny (and
am driving down from Hamilton, Ontario, Canada) and
need help Friday afternoon/early evening putting them on...
I have never done this, and Denny & Beth suggested that they can help and
that I might be wise to ask help from other people with experience.
I have power windows and locks, I can dismantle my old doors (mirrors/iniside door panels/armrest, etc) but lack the confidence to properly hang/mount new doors...heeeeeelllllllpppppp!
I would be willing to reward experienced helpers with say...."Canadian Club"???
Please let me know your Thirgen Fest '08 ETA if interested - I will plan accordingly!
Neal Humby
Mar 14, 2008 | 07:27 PM
Re: Thirdgen Fest '08 NEED HELP WITH DOORS!
a floor jack and an extra pair of hands is all you need.
long 1/2" breaker bar, whatever size door bolts are on the inside by the kick panel you'd need a 1/2" deep socket for, preferably impact sockets. around here you can buy a set from a parts store for relatively cheap and they never break. then various extensions and a ratchet should do it. 6 bolts i believe hold the doors on, then lining them up is a bit of a pain.
Mar 26, 2008 | 09:57 AM
thankyou xpndbl3...got the breaker bar, will get the rest...should I score the old bolts position? I guess I'm gonna learn something new! Can't wait to hear those new doors close!
Mar 26, 2008 | 10:30 PM
you'll see the outline of where the old doors were on the door frame when you remove them for sure, it'll look like brand new paint underneath. Not too bad a job swapping them I'd imagine. good luck.
Mar 28, 2008 | 04:34 PM
i believe the bolt sizes are 13mm and 15mm.
unfortunately i believe the fenders need to come off.
o well, you should know when you go to denny and beth's youll have all the help u need!
Mar 28, 2008 | 09:21 PM
ya removing the fenders from the back isn't too bad, just a few bolts here and there, and that dreaded bolt from underneath, maybe you should have that one broken loose before heading down here.
Apr 1, 2008 | 12:57 PM
Quote: ya removing the fenders from the back isn't too bad, just a few bolts here and there, and that dreaded bolt from underneath, maybe you should have that one broken loose before heading down here.
do I really have to remove fenders? I see two bolts underneath...one in front of tire, one behind...(berlinetta) any help would be appreciated!!!
Apr 1, 2008 | 06:41 PM
ask on the body board on the main page and someone will know for sure, I haven't taken them off in 3 years so I'm a little fuzzy, I'm pretty sure they need to be at least moved out of the way.
Apr 1, 2008 | 06:58 PM
you dont have to remove the fenders. that would just be a nightmare. you would have to remove the hood to do that anyway. all you have to do is remove the kick panel on the inside and remove the splash guard or plastic lining inside the wheelwell. I did mine that way by myself with no problem. Its a little tricky getting the to bolts in the back of the hinges to start but with one guy on either side of the door to get it lined up you shouldnt have a problem.
Apr 2, 2008 | 10:58 AM
Quote: you dont have to remove the fenders. that would just be a nightmare. you would have to remove the hood to do that anyway. all you have to do is remove the kick panel on the inside and remove the splash guard or plastic lining inside the wheelwell. I did mine that way by myself with no problem. Its a little tricky getting the to bolts in the back of the hinges to start but with one guy on either side of the door to get it lined up you shouldnt have a problem.
thank you Skinny...that I can do! Also thanks to everyone's tips!!!
see you all there!
Apr 12, 2008 | 11:50 AM
Well you have to drop the rearend and the gas tank first before you can install new doors Neal
Apr 17, 2008 | 10:04 AM
Quote: Well you have to drop the rearend and the gas tank first before you can install new doors Neal
Oh no! I guess I'll have to remove my spare tire and my cooler with canadian beer too! lol
Apr 23, 2008 | 08:52 PM
I'll help with the beer. Oh and the doors too.
Subscribe
