OLD Third Gen Fest Discuss plans for the IL gathering set for May 27th-28th.
I'll be there
Old Mar 12, 2001 | 09:46 AM
rondubbs's Avatar
I'll be there
This event sounds real cool,, i cant wait to go and check out other fbodys in the area..
Old Mar 12, 2001 | 02:25 PM
theformula's Avatar
I'll be there too if I can get my POS tuned by then
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 12, 2001 | 02:35 PM
The Rusty Trombone's Avatar
I'll be there also, hopefully my car will be painted by then, and Im most likely bringing my friend along with his 2000 SS... kickass!
1987 Midnight Blue Camaro IROC-Z, 350 TPI out of an '88, Accel 8.8 wires, hypertech air foil, flowmaster american thunder 3" dual outlet cat-back... slipping tranny!! (T5 swap next spring!!)
http://banners.wunderground.com/bann...hackensack.gif
Old Mar 12, 2001 | 03:15 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
I thought the closest one was in Ohio this year! This is great news! I'm sooooo there
http://www.tcnj.edu/~esposit3
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Mar 12, 2001 | 03:21 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
I'll be there, and if everything goes well my car will be painted by then. Hopefully I can staighten out my chip problem too by then and see what she'll do.
Just curious, Englishtown is a really nice track right?
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s.
Old Mar 12, 2001 | 05:03 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
Im definately goin!!!
My 1986 Z28 and more!!
85 IROC w/ 1364 miles!
R.I.P Dale Earnhardt
Old Mar 12, 2001 | 08:39 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Count me in, I'll most likely be there, ive been waiting to find some kinda fbody thing close to home, and 20 minutes from the house is close enough for me. see you all there!
1991 Camaro Z28
ENGINE/MECHANICAL MODS:
350 TPI, automatic, Edelbrock Headers, Edelbrock Runners, Flowmaster Exhaust, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000 Reciever, Q-Logic Dual 10" Bandpass Box, 2 10" MTX Thunder 7000 Subs,
Rockford 250a2 Amp, Infinity Kappa 4x6" plates & 6x9's
Visit my website and see pics at: Frank's 1991 Chevrolet Camaro Website
Old Mar 13, 2001 | 05:39 PM
NJ SPEEDER's Avatar
mike89z,
e-town is a great track. i am not just saying that because it is my home facility either. i have been to literally dozens of race tracks in my life and it is one of the nicest you'll find. the track is always well groomed, the grounds are clean, and the food is actually pretty good. it is also one of only a few tracks in the country that you drive under the media tower to the starting line which is really neat.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Mar 14, 2001 | 01:28 AM
Z-Rated Motorsports's Avatar
But of course we''ll be there Miriah, sporting some new times. Hint, look for the roll cage, fire jacket and 5 point harness!
Owner Z-Rated Motorsports
Old Mar 14, 2001 | 11:36 PM
theformula's Avatar
E-town is the nicest track I've ever seen.
Old Mar 15, 2001 | 09:45 AM
NJ SPEEDER's Avatar
actually the easiest way to se what e-town looks like is to watch the matco tools supernationals on tv. it is towards the end of may, not sure what weekend. you will get to see what a true high class facility looks like.
lata
tim
Old Mar 16, 2001 | 02:36 AM
PROCHARGED89Z's Avatar
Im going too!Caint wait.
Old Mar 18, 2001 | 04:08 PM
rondubbs's Avatar
sig test
1988 GTA Trans Am 350tpi: 45k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, flux capasitor, driver side floor mat removed
Old Mar 19, 2001 | 11:51 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm going to try my hardest to get there. I'm pretty sure I'll be able to get there.
My car should be all ready. It's got the new engine in it, now all it needs is a hood, new torque converter, and posi 3.73
After that's all done then she's getting a paint job and maybe even some new seats.
About Englishtown: It's probably one of the best if not the best tracks on the east coast. Even National Trail out where I'm going to school (Columbus Ohio, home to Jegs) isn't as nice. It's at sea level, one of the best tracks ever, good food like Tim said, and the best cars/shows.
After typing all this I'm going to have to say I'LL BE THERE!!!, no maybe's, I'll call into work sick if I have to.
, Jon (in process of installing new engine)
Old Mar 30, 2001 | 07:35 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I should be there, look for a twin or single turbo LT1 powered 86 Z28, blue with silver gfx. :-D
