Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Another 'How will this combo run' question ;)
Old Apr 21, 2002 | 01:15 AM
EvilCartman's Avatar
Car: '82 Z28
Ok, just in the planning stages right now but here's what I've got on paper..
BBC 454
Eagle steel crank
Eagle steel rods
Speed Pro Hypereutectic 10.2:1 pistons (not going to run a bottle)
Roller rockers
CraneCams PowerMax CC-314-2 (mechanical)
Adv. Durarion: 314°/324°
Gross Lift: .567''/.590''
Iron heads with 2.30 intake 1.92 (I think) exhaust valves, have been "worked to the max" as the guys says (unknown what type)
Holley 850 cfm
Torquer intake
Hooker Supercomps running into dual 3inch exhaust
Rebuilt TH400 w/2500 stall, 3.73 gears
Figure stock car weight
The heads I was told are the same being used on a chevelle that runs 11.50's, they're the guys backup heads which have been setting around for a while now. Thanks for any input!
Old Apr 21, 2002 | 09:56 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Providing you build the suspension to be able to get the power to the ground, it should easily run 11's.
I think the cam has a bit too much duration for the amount of lift. What's the LSA?
Old Apr 21, 2002 | 07:38 PM
Car: '82 Z28
LSA looks to be 110.. Duration at .050 is 248 intake 258 exhaust. Yeah, going to really have to do some work on the suspension cage plus subframe connectors are a must lol.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
