Engine Torque Chain.
Car: 1986 Z28
Engine: 355
Transmission: th400
I'm going to chain the engine in this week, in my 86 Z28.
How much slack, if any should be in the chain. I figured on as little as possible.
Right now the plan is to attach it to an accesory bolt on the driver's head, and then weld a link to the flat part of the "frame"
any other method's, places or suggestions as to where the frame side of the chain goes
The heads are iron, and the only accesories are the waterpump, and the alternator, so there's not a lot of intereference here.
thanks
thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since the amount the engine rocks in the rubber mounts is very little, any slack in the chain is useless. You want the chain tight but not pulling down on the engine. Using a turnbuckle can fine tune the adjustment.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
