Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1/4 mile guru's....hazzard a guess?
Old Feb 28, 2003 | 10:44 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
OK, car is almost finished and will be taking to track when it gets warm enough here. I am looking for some honest opinions on 1/4 mile times for this beast:
91 Formula weight 3500 w/driver
406 bowtie block - 11.5:1 comp
AFR 210 heads - right out box with 2.08/1.6 valves
Solid roller cam 248/248 @ 0.050" with 615/615 lift 110 LSA
TPIS miniram / 58 mm TB
Evans coolant
Level 10 Prepped 700r4 w/ 9.5" 3200 Vigilante Convertor
Strange 12-bolt w/ 4.11 gears
M/T 26x 10.5 drag slicks
aftermarket T/A, LCA, Panhrad rod,
Eibach drag springs/Lakewood 70/30 struts / 50/50 shocks
PA racing Tubular A-arms
Jegster Frame connectors
Old Feb 28, 2003 | 11:03 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Sounds like you have a nice set up that will make plenty of power, the hard part will be getting all that power to the ground. 4.11 gears with the low first gear of a 700-R4 might make it difficult for you to hook up. If you can get good traction (1.6x 60' or less) you should be able to get into the mid 11's or maybe even low 11's.
Old Feb 28, 2003 | 12:37 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
The car hooked well last season (1.63 60') and ran 12.20 @ 111 while only putting 345 to the rear wheels.
So the suspension should be up to the task.
Since last season though, switched heads, pistons, cam, went from SLP headers to Hooker Super Comps.
Old Feb 28, 2003 | 05:02 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Should run mid to low 11's. With the right tweaks, weight reduction, suspension, high 10's.
Good luck.
Old Mar 7, 2003 | 07:56 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
anyone else?
Old Mar 8, 2003 | 07:07 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: 1/4 mile guru's....hazzard a guess?
Evans coolant
Seeing as you should be close to or pushing 600 horsepower, I would be pissed if it didnt go high 10's or better with good traction. Honestly, you need shave some weight off that damn car lol. 3500 pounds is too much if you want to put some good times down. Also, why are you going fuel injected, you gonna try and drive it on the street? Seems like a carb and single plane would be easier to me but oh well. Good luck!
Old Mar 8, 2003 | 07:20 PM
Zenger's Avatar
nice combo man!
I would venture a guess at low 11's with everyone else
combo is similar to my 406 combo!
Good Luck this season
zach
Old Mar 8, 2003 | 08:54 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
lethalracer and 11sec91z are both running similar setups but i believe they're in 383's. 11sec91z is hoping for high 10's (he's running 11.21 atm) and lethal is running 12.0, both with stock suspensions.
58mm minirams
ZZX cam (240/240 596/598 112lsa)
afr 195s
11.2-11.5 cr
n/a
i believe 11sec91z is running stock injectors and fuel pump to boot...if you can tune and hook, i don't see any reason you can't get high to mid 10's.
Old Mar 8, 2003 | 11:21 PM
25THRSS's Avatar
I agree with everyone else
Old Mar 9, 2003 | 09:58 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Cool. Thanks for the replies everyone.
I do plan on running this car on the street as it is a street car.
I should be able to post the first timeslips early in April.
Thanks again guys!
chazman
Aug 28, 2018 03:25 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
gta90
Sep 15, 2015 04:00 PM
chazman
Aug 22, 2015 02:01 PM
formula_novice
Aug 18, 2015 08:48 PM
