Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
The Little 305 That Could
Old 05-16-2003, 11:29 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Transmission: 6 Speed
Axle/Gears: 9" 4.11 Truetrac
this car just keeps on impressing me. last fall i ran a 13.9 @ 97.08 with:
Ported Plenum
Centerforce Dual Friction
Poly Tranny Mount
Poly Torque Arm Mount
Modified Air Box
K&N Filters
Dynomax Headers
Dynomax Cat Back Exhaust
Hollowed Cat
Throttle Body Coolant Bypass
IAT Sensor Relocated
Emissions Delete
AC Delete
No Spare Tire, Jack, Rear Seats
Now My Best Times are 14.2 @ 99.76 with a 2.3 60ft and a 14.3 @ 100.2 with a 2.4 60ft
With:
LT1 Cam
Ported Plenum
Poly Tranny Mount
3.27 9 Bolt Rear
Modified Air Box
K&N Filters
Dynomax Headers
Cat Delete
Emissions Delete
HVAC Delete
12* Base Timing
No Rear Seats, Spare Tire, And Jack
Toyo Proxes FZ4s
Descreend MAF
i was running 97-98mph with the stock MAF unit. then my friend let me use his gutted MAF sensor and i went the 14.2 @ 99.76 and the 14.3 @ 100.2. so the LT1 cam made the car run a lot leaner, with the gutted MAF it ran a lot richer. this explains why i didnt get a whole lotta difference between the stock cam and the LT1, but now i do!
and yes it is a 305 the block says 5.0L G on in the cast on the back side.
Old 05-17-2003, 11:58 AM
MdFormula350's Avatar
great times, your 60 foot needs some help now, maybe an adjustable torque arm might be something to think about or lower control arm relocation brackets.
Old 05-17-2003, 02:44 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Great times!
Why does a gutted MAF make your car run richer?
Old 05-17-2003, 05:45 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
305's can do the job. My 84 HO Z28 ran a best of 13.89 back in '87. Once you get those short times down to at least 2.0, you should be running 13.5 or better.
And of all the gutted MAFs that I've used and heard of, it leans it out. More air flow coming in with the old calibration makes for a leaner mixture.
Congrats!
Old 05-17-2003, 06:25 PM
25THRSS's Avatar
Congrats!
i agree
Old 05-17-2003, 06:52 PM
BADDEST305's Avatar
Car: 1991 z-28
Engine: 434--654hp---601 torque
Transmission: ATI POWERGLIDE
Axle/Gears: mose 9" / 411 gears
good job!
Old 05-18-2003, 12:14 PM
BadBowtie88's Avatar
Do something about those 60ft times man. 2.45 and 2.33... Pull those down to around a 2.0x and you'll be all over the 13's consistently. Nice times.
Old 05-18-2003, 12:58 PM
Marc 85Z28's Avatar
I agree. Those are still some good times for a 305.
Why go with the LT1 cam? That isn't much of a step up from the 5 speed 305 TPI cam - and all that work...
BTW - In that first run, what did you race, an 03 Cobra? 17.4@74 doesn't belong at a track. If you've got a car that slow, quit taking up space
Old 05-18-2003, 01:02 PM
Amen.
Old 05-18-2003, 01:46 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
haha the 17.4 was my freinds lifted up ford F 150. i choose the lt1 for reliability issues, i dont have time to burn computer chips or deal with a tempermental engine. i put 2k miles on this car in three weeks so i gets driven a lot. definitly needs traction work haha 1st and 2nd gear rubber at the track is not good. i have no idea why it runs better with a descreend maf my BLMs at idle are 134 with the stock one and it seems to run a **** load better with mine descreend now. i hate hacking things and i used to tell people how bad it was to descreen but it seems to be doin better with em out? is it possible im excedding the 255 grams per second flow rate the computer is capabil of reading?
Old 05-19-2003, 03:12 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Your times were slower but your trap speed went up?
Old 05-19-2003, 08:49 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
yeah i cant hook up for **** now. 4 tenths slower off the line is 8 tenths slower at teh end of the track, a 2.0 60ft would get me a 13.5 or 13.6. it needs suspension mods badly
pjsparts
09-17-2015 01:28 PM
Ranbo108
09-09-2015 12:20 PM
383cam
09-09-2015 06:01 AM
rsrookie
09-05-2015 07:08 PM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: The Little 305 That Could
