Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Ok, heres where I get a little lost...
Old Jun 7, 2003 | 12:16 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I understand e/t = pretty much how good you hook up. Trap speed = How much power your making.
I compared one of my time slips with another members L98 on the board.
His 60 ft: 2.27...............Mine 2.28
His e/t: 14.6 .................Mine 14.8
His Trap 93.5mph..........Mine 94mph
With similar 60ft's and my trap .5 higher, how come he is .2 faster?
Old Jun 7, 2003 | 11:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Maybe he has better gears.
Old Jun 7, 2003 | 11:41 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Gearing, shift point, wind direction, launch rpm plus many other factors can change an ET.
Your MPH indicates a slightly high HP but that doesn't mean you'll run faster.
When I still had a 383 SBC, I was running 12.0 at 117 mph and 1.7x 60 foot times. Typically a 12.0 car should be around 110 mph and a 117 mph car should be around 11.4. My problem was that I was using 3.27 gears at the time. I was actually slow off the line compared to other 12 second cars but while they were topping out at the end of the 1/4 mile I was just starting to get into the power curve and would blow past them doing the same ET.
You could spin off the line and get a poor 60' time and ET but still run your mph.
Everyone is always concerned about their ET. Ignore the ET and concentrate on the MPH. When you tune an engine for more power, watch the mph of the 1/4 mile. The higher you get it, the more power you have. ET will just come along for the ride. Once you have more power than traction, then start improving driveline, suspension, tires to lower the ET in relation to the MPH.
Old Jun 7, 2003 | 01:05 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thank you for taking the time to explain it to me :hail:
Bigboi
Aug 6, 2015 08:51 AM
TC3G89
Mar 1, 2014 02:34 PM
jake.sala
Jan 30, 2013 04:31 PM
pvr007
May 11, 2012 09:59 PM
pandemic_ratio
Aug 21, 2006 09:21 PM
