Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How is he running these times ??????
Old Oct 22, 2003 | 10:47 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I met a gent at the track with a thirdgen a couple of weeks ago ...and i have been trying to understand how the heck he is running a 10.5 with this setup
ZZ4 crate motor
stock .474/.510 ...208/221@.50 112LSA camshaft
stock 113 casteing heads ( 58 cc ) with porting ( he says a little )
10:1 flattop forged pistons
4.56 gears in a moser 12 bolt.....but 30" tall tires
dual plane intake
Holley 750 double pumper
no nitrous , no charger , no turbo
I seen it run .....man it was sweet ......so smooth I could have driven it home . The guy just kept laughing as I burned braincells as to why he was getting these wicked times
Old Oct 22, 2003 | 11:58 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Re: How is he running these times ??????
I would bet money on the fact that he is pulling your leg - there's no way that engine will go 10.5's in a third gen.
Old Oct 22, 2003 | 12:26 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I seen the outside of it ......... and alll I really could tell about it for sure was ....
it had a dual plain intake ......and it was a smalllblock .....and they were the 113 casteings ( stock ZZ4 heads ) .
and I did see the track times
Old Oct 22, 2003 | 01:05 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
How do you know the casting number of his heads? They are located under the valve covers. In any case, it is not physically possible for a stock ZZ4 engine to get a third gen anywhere near 10.50's (naturally aspirated). Sorry, this guy was taking you for a ride.
I believe that the car ran those times. I just don't believe he was telling you the truth about his engine.
Old Oct 22, 2003 | 01:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Perhaps a fogger system plumbed under the intake.
Old Oct 22, 2003 | 01:13 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
The car weighs 1500lbs.
Old Oct 22, 2003 | 01:21 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
it might just be me but i get the feeling he's not telling you something..<----
Old Oct 22, 2003 | 01:33 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Even if it weighed 1500 lbs, a stock zz4 motor isnt going to make the torque to justify a 30" tall slick, let alone make one spin.
Old Oct 22, 2003 | 01:35 PM
And the zz4 has hyp. pistons, so if it has forged pistons that tells you right there that the engine has been apart. I am guessing it is some crazy stroker motor / nitrous motor.
I would bet it is some crazy stroker motor, and the additional displacement masks the sound of a larger cam.
Old Oct 22, 2003 | 02:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Welll ..... he told me ( now I feal really dumb )
but ...... ya I agree that the motor has been apart with ....him saying it has forged pistons ........ but I never seen any solinoids .... extra fuel lines or anything under the hood . It was pretty clean .
I am starting to believe it is some crazy stroker motor . Just think he was selling it for around 18'000 . I wish I would have gotten his number . He says it was a registered NHRA car ...... frig I wish I had a way of looking for a picture of it on the net ...kinda like a mug shot ..... becasue I could pick it out noooo problem . Thanx for the feedback all ....... I just thought there was some nasty seceret to makeing gobs of power ....... I was running his cam ...and same pistons ...same C/R ...... sure my heads ain't aluminum ....but they had work done to them
thanx again
Old Oct 22, 2003 | 04:03 PM
thanx again
Just to show the lengths people will go to build a sleeper motor, a friend of mine is having camel humps machined onto the front of a set of dart 230cc raised runner heads that flow close to 320 cfm on intake .
Old Oct 22, 2003 | 08:10 PM
86 IROC's Avatar
I'm not saying his motor was 100% legit... but has anyone ever read up on the crate motor class cars? They disected one in an old issuse of HOT ROD. It was a 1st Gen Camaro w/ a Fast Burn 385 motor... ran in the 10's IIRC. If I can dig up that old isssue - you can bet your *** I will post it.
Another thing to consider is Stock Eliminator cars, they launch like a SOB & ET crazy w/ sub par MPH.
Old Oct 22, 2003 | 08:30 PM
Slow84Z's Avatar
Car: 84 Z28
Engine: 305 HO
Transmission: Slippin' 700R4
I've seen that article in Hot Rod with that 1st gen running 10's. I don't have it with me (here in college).
Old Oct 22, 2003 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
But the specs he quoted are nowhere near a stocker and that's how they make most of their power.
Personally I think he's pulling your leg about what he's got. The car either needs to weigh below 2500 pounds (not likely) or has a hidden NOS system in it or is really a huge SBC 434 etc. They make a cool NOS system now that hides inside the air cleaner. You can also hide it inside the intake manifold.
I could tell everyone my engine is only a 396 and there's no real way anyone can prove it without a teardown.
Old Oct 23, 2003 | 02:42 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
Swamp land in Florida comes to mind!!!!
Old Oct 24, 2003 | 12:00 AM
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
The suspension, converter, tranny stuff that makes a stocker fly will really make a hotter motor crank. At the just completed Dutch Classic at Maple Grove both Brian Van Poppel and Dave Casey set new national records with their 305 stockers at 10.91 and 10.98 respectively. Put a bigger cam in the same car with a better carb and intake and take a wild guess at how much more they might pick up. And 30" tires aren't the et killer you might think. Last year I ran 4.56's and tried a 30" tall radial slick in place of my bias 28's for couple passes. Barely any et difference at all, keep in mind a radial slick won't grow like a bias one plus they're worth a tenth over bias as well comparing equal size tires.
Old Oct 24, 2003 | 08:45 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
I agree with having the car set up right, but you still have to have xxx amount of horsepower to get a certin et for a particular weight car. No?
Old Oct 24, 2003 | 04:53 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I be thinking he was full of it ....thanx all
I just had to know how the heck he got that thing sooooo fast ........like I am sure the HP is through the to run 10's I figured I had a chance if I had this "magic" seceret
Old Oct 24, 2003 | 09:38 PM
mod313's Avatar
Car: Camaro
Think about this. Those guys ran 1.9's with a 305 at just over 3000 lbs. Add 45 cubes, better intake, bigger cam, port work to heads (not allowed in stocker motors), better larger carb, etc and wouldn't you agree the 4 tenths better is vety reasonable if his car is class ready as he states?
Old Oct 24, 2003 | 11:54 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
ya we call that lying around here
Old Oct 25, 2003 | 01:39 AM
Then it wouldnt be a zz4 engine would it?
Old Oct 25, 2003 | 08:08 AM
mod313's Avatar
Car: Camaro
So you're now saying the ZZ4 350 isn't 45 inches bigger than a 305?!? And the ZZ4 cam isn't bigger than the smaller cam in the 305? And the 750 carb isn't bigger than the 650 cfm q-jet we have to run? And the aftermarket intake isn't better than the stock one we have to run? And you're forgetting the guy was said to have admitted a touch of port work, something we aren't allowed to do at all in Stock. All this stuff adds a bunch to torque output, and like I said, if you couple the better sorted car to this motor you don't believe that 4 tenths is reasonable? And this is assuming he's at equal wt, if he's 100 or 200 lbs less there's a tenth for each 100. Makes the 4 tenths even easier to pick up.
Old Oct 25, 2003 | 02:39 PM
The way you worded it I thought you meant take a zz4, add 45 cubic inches to it, a bigger cam and port work. My bad.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
