Back from track, need new posi
Car: 1992 RS Camaro bracket car
Transmission: TH-350
Car ran okay...at least the engine. now pulls through 6500 RPM. Now have a very weak posi unit. First the left slick spins then the right slick. You can feel it alternating all the way down the track.
Does any one have opinions on differing diffs? Eaton, Zexel Auburn?
SLP has take offs, could these handle a 305, stall converter and slicks? Current best time is 8.67 in 1/8 th mile w/201 60 ft time.
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
It should, before I got my Strange 12 bolt last winter I was running the original rear in my car. It had 4.56's with mini spool, ATI 8" conv w/ 5200 stall and ran mid 1.5's for 60' times. This is how it launched last year, I tamed it down a bunch last winter to get it more consistant.
Car: 84 Z28 Camaro
Engine: 350ci
I got the Zexel on sale for $79 and through it in with Moser
axles. 60ft went from 2.0x to the 1.79 I just pulled last
weekend. How it works out in the long term... ??
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've got a factory posi with over 120K on it, still performing great after 2 full seasons of abuse and 3 rear ends
I can tell it's worn cause if the staging to water box is a tight turn I have to back up straight about 10' otherwise the wheels will spin intermittedly in the water. Gettin the Ford 9" this winter with Detroit Locker.
I used to have an Auburn unit in my old car and that worked as well as a posi is supposed to for 2 years.
I can tell it's worn cause if the staging to water box is a tight turn I have to back up straight about 10' otherwise the wheels will spin intermittedly in the water. Gettin the Ford 9" this winter with Detroit Locker. I used to have an Auburn unit in my old car and that worked as well as a posi is supposed to for 2 years.
Is it the locker type? Mine stopped pulling both wheels after a tight turn into bleach box area. Kept pulling intermittantly the rest of the run.
I've never had this factory unit apart, but I assume it's a clutch pack type.
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
