Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
i finally went to e-town.
Old Nov 8, 2003 | 10:17 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
me and my dad trailered my car down there last night. this is the first time i have ever raced. it was such a blast. i can't wait until the spring so i can do it again.i am however very disapointed in my times. my first run was a 15.3, second run was 14.9, and the last was a 14.5. i definately thought the car would run low 13's considering the size of the engine thats in it. i think this winter i'm going to redo the top end of my motor with a bigger cam, afr heads, and better intake maniflold. i really think that the car should be in the 12's with out any problem. the car also runs very rich and i have to bump the timing up alot more. i just wanted to get an i dea of what the car runs before the winter comes. alot of guys were telling me that i wasn't happy with my times because i am new to racing. they said that once i start doing it alot i'll start seeing better times.i guess thats true because my first run was a 15.3 and my last was 14.5. im also going to get a set of drag radials. i could not get my car to hook up. everytime i spun them pretty bad. oh well, ill see how i do in the spring will the heads, cam and intake done over the winter. i thought that i would share my experiance with everyone. the only pics i have is of the car on the trailer. sorry no action shot. it was to dark for my camera.
Old Nov 8, 2003 | 11:18 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you are that rich I bet if you leaned out abit you will see a lot better times. I have seen some cars dyno 17 higher at the wheels with the right fuel adjustment because they were that rich.
Old Nov 8, 2003 | 01:11 PM
Mad-Mic's Avatar
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
dude that cam is way to small to wake up that 409 sbc! wake that thing up with atleast a 228 duration 525" lift or better cam!
Old Nov 8, 2003 | 03:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was thinking the same thing. It would be a hot cam in a 283 or 305 but a bigger engine needs a bigger cam.
What were your time increments at the track? 60' 1/8 mile etc.
Old Nov 8, 2003 | 03:24 PM
BADDEST305's Avatar
Car: 1991 z-28
Engine: 434--654hp---601 torque
Transmission: ATI POWERGLIDE
Axle/Gears: mose 9" / 411 gears
hey i saw you there i could tell you were having a blast by the smile on your face!! good luck with the car
Old Nov 8, 2003 | 03:38 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I also just looked at that cam and it is small. You may want to look into the LT4 hotcam or the CC306 cam that is also for Ltx engines. For a 409 I would get something scary.
Old Nov 8, 2003 | 04:56 PM
Nitrous Al's Avatar
Car: '90 Mercury Grand Marquis GS
Engine: 5.0L Ford V8
Transmission: AOD
Axle/Gears: 8.8" Ford, 3.08:1
Sweet looking car you got there!!!
Old Nov 8, 2003 | 05:27 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Your current combo is pretty tame IMO. Good luck with the mods and the car. What was the whole time slip, and what's the entire car's setup?
Brady
Old Nov 8, 2003 | 06:48 PM
Car: 84 camaro Z28
Engine: 434sbc
BADDEST305, i didn't know that you were a member on this board. thats cool. i'll probably be seeing you down there in the spring.
im really not to wise with cams. the guy who built my motor with me picked it out. the motor was built for an everyday driver, so it had to retain street manners. once i painted my car, i decided that i wasn't going to drive the car everyday. then my dad bought a new truck(the green one in the pick) and he gave me his old one. so i pretty much never drive my car. as far as a bigger cam, i still want to be able to drive the car on the street with no problem but i want to be able to race on the weekends. what would you guys recomend. i'm going to make a post in the engine swap board so i can get recomendations for a cam, heads, and intake.
and here is the whole time slip. (my best time of 14.5)
R/T .670
60 2.321
330 6.267
1000 12.210
1/8 9.474(76.68mph)
1/4 14.585(90.92mph)
let me know what you guys think
Old Nov 8, 2003 | 07:27 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
I definitely agree about the cam plus I would get a RPM, or RPM Airgap intake also cause the performer is basically an aluminum replacement for a steel stocker except hat it takes a holley carb.IMO
Old Nov 8, 2003 | 09:09 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
R/T .670
60 2.321
330 6.267
1000 12.210
1/8 9.474(76.68mph)
I see that your 60' is killing you! You must be spinning half way down the track with all that TQ!!!! YOU NEED SLICKS!!!!!!!
Old Nov 8, 2003 | 09:17 PM
BADDEST305's Avatar
Car: 1991 z-28
i told you last nite that some slicks would help keep the ones i told you i had in mind when your ready for a set.
Old Nov 9, 2003 | 09:54 AM
Car: 84 camaro Z28
Engine: 434sbc
yeah i spun them everytime. won't slicks destroy my trans and rear.
BADDEST305 when im ready to get the slicks i'll drop you an email. thanks.
Old Nov 9, 2003 | 04:21 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
slicks will help alot, they kinda did for me. my best was a 15.6 at 88.88mph with a 2.32 60' with my dot slicks that have about 20 runs on them. they gave me the traction i needed but not enuff and i think 3.23 gears are kinda killin my 60' times becuz now withthe added traction i cant move quick enuff, but 3.73's should fix it.
try some slicks even if you can get them for cheap, i got mine for $50 and they have some life left in them.
Old Nov 10, 2003 | 08:30 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
R/T .670
60 2.321
330 6.267
1000 12.210
1/8 9.474(76.68mph)
let me know what you guys think [/B]
There is room for improvement on your 60', but you only trapped at 91? That is quite a low e.t. for a 2.32 60' and that trap speed. Where you on the gas all the way pass the finish line? What were your other trap speeds?
Old Nov 10, 2003 | 04:19 PM
Car: 84 camaro Z28
Engine: 434sbc
heres my other 2 time slips
R/t .715
60 2.391
330 6.373
1/8 9.709(74.96mph)
1000 12.554
1/4 14.923(95.64mph)
R/t .665
60 2.579
330 6.882
1/8 10.202(75.46mph)
1000 13.032
1/4 15.398(95.72mph)
Old Nov 10, 2003 | 04:33 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
You trapped higher in the 1/8th on your best ET.
I bet you let off too early (hence the lousy trap). I bet you would have had 97 mph on the last run and maybe a better ET too!
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
