Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New Best Times
Old Feb 28, 2004 | 08:52 AM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
New Best Times
Went to track last night to break in rebuilt 350. Car ran 7.91 @ 86 MPH in 1/8th mile. This is with limiter restricted to 5,500 RPM and short slicks (26"). Traction was virtually non existent as there were not enough cars to warm track surface. Had to leave early as cords were showing on one rear tire.
Will change oil and tires today for another session tonight.
Old Feb 28, 2004 | 09:25 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Steve
Old Feb 28, 2004 | 01:11 PM
MdFormula350's Avatar
sweet times, hopefully you can hook up for even better times.
Old Feb 29, 2004 | 06:22 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Nice first run with the new motor. Tell us a bit about the new 350.
Old Feb 29, 2004 | 09:11 AM
muggsyjack's Avatar
Saturday night car ran quicker: 7.68 at 87.5 in 1/8 mile w/1.61 60' Engine is still on break in restriction, shifting at 5000 to 5200 RPM. The shortblock is a circle track 2 bolt 350 w/flattop pistons. Heads are Iron lightning 200cc intake/50cc Chamber for 11.4-1 Comp ratio, 2.02 Int./1.60 Exh. valves. Manifold is dual plane airgap, 750 Vac. sec. Holley w/choke removed. Secondary conversion plate installed. Hooker 1-5/8 long tube headers.
Other items: TH-350 w/3500 stall converter, 4.10 gears, torson diff, Lakewood LCA and Adj. Panhard bar, Air bags, 90/10 struts, M/T 28 X 10.5 X 15 Slicks on 15 X 10 Rims.
Adding SFC this week and ordering 8 pt rollbar and seats/harnesses.
Replaced 305 as bores were worn out, cranking compression dropped to 120 to 150 across all 8 cylinders. 305 had run a best of 8.07 @ 85.5 MPH in 1/8th w/1.77 60' time before starting to slow.
Old Mar 2, 2004 | 06:46 AM
Blackroc86's Avatar
Car: 1986 Iroc
Nice run. Can't wait to see what it will do when you unleash it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
