Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
AeroDynamics
Old May 13, 2004 | 08:39 PM
JonDeere's Avatar
Car: 94 3500 4WD
Engine: 6.5Turbo
Transmission: 4L80E
AeroDynamics
Does anyone know what year and what front clip [camero\firebird] has the least air drag, going to build and run at the new track in S.C. , called the Standing Mile.
Any Info would be helpfull
Old May 13, 2004 | 10:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your own personal preference to what you like.
Firebird are more aerodynamic than the Camaro because of the hideaway headlight design.
Frontal area on the Camaro are all the same except for cosmetic changes between models and years. I personally like the Z28 nose piece.
Unless you start getting over 150 mph in the 1/4 mile, you're not going to see much difference in aerodynamics between all the third gens.
Old May 13, 2004 | 11:01 PM
JonDeere's Avatar
Car: 94 3500 4WD
Engine: 6.5Turbo
Transmission: 4L80E
230mph
230mph is close to what I'm aiming at, I've heard plexiglass inserts on the headlights help on the camero.
Still need info on coeffincent drag between the two models, has anyone tried bellypans?
Old May 13, 2004 | 11:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Your not going to find any info on that type of racing in this forum. You might want to try hre.com Many of the racers on that forum also do the Bonneville racing.
Typical drag coefficient of a third gen is 0.33
The plexiglass inserts for a Camaro don't survive at high speed. That's why I don't have them on my car. They're only made for street use. Even in the 80's when ProStock used third gens, they didn't use the headlight covers on the Camaros. That's also why most of the ProStocks were using Firebirds. The aerodynamics were just a little bit better.
Old May 14, 2004 | 07:47 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Actually, with headlight covers, the TA and Camaro are the same. But the TA due to the sealed front end - no radiator air inlets has more of a tendency to lift (more air get trapped under the hood) than the Camaro does. The underbody is the same. The rear of a Camro is probably slightly better, because the TA has a spoiler that protrudes farther up into the airstream than the lip spoiler on a Camaro.
You won't have a chance at running 230mph in the standing mile -even turbo hayabusas barely touch that speed - and they run 165+ in the quarter mile.
Old May 14, 2004 | 11:41 PM
JonDeere's Avatar
Car: 94 3500 4WD
Engine: 6.5Turbo
Transmission: 4L80E
Thank Ya'll for the info, and yes sir, they are hitting 2and 1/4, 230mph is possible
Old May 15, 2004 | 12:20 AM
SuperchargedRS's Avatar
Car: Camaro of course
I forgot the website but it was something like "smokeemup" or "litemup" .com anywho, the camaro can go as fast as you have hp and torque to take it. I found w/ 700Hp and 750lbs of tq I could get a camaro (stock configuration of body) up to something like 180mph. I'll look for that website
Old May 15, 2004 | 12:30 AM
Not the exact site but still:
http://www.geocities.com/MotorCity/7610/aerodyn.htm
Old May 17, 2004 | 08:39 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
One of the early firebird formulas with 0 options had the lowset coefficient drag of any car GM has ever built, it was a low .23.
Does anyone else remember reading this?
Old May 17, 2004 | 03:54 PM
paul_huryk's Avatar
That's my webpage!!!!!!
Old May 17, 2004 | 05:17 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
No. That was This.
There is also an entire Coefficiant Drag list for Third Gen's in our Tech Data: https://www.thirdgen.org/newdesign/tech/techdb.shtml Basically they are the same with the Firebird being usually at least .2 Cd better while the Camaro's spoiler works better.
Old May 18, 2004 | 08:50 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
hey, im in SC..
any more info on this track? the Standing Mile?
87hellbird
Sep 24, 2014 10:08 AM
jollythought
Nov 19, 2012 11:58 AM
bigbird89
Nov 21, 2008 02:24 PM
CrispyClutch
May 14, 2003 09:59 PM
1984-Firebird-SC
Jan 2, 2001 03:41 PM
