new best time so far
Car: 1985 Firebird
ok heres my new times i am very happy with them but i have alot of tunning left to do
attached is my time slip
and my car specs
keep in mind this car is my daily driver (i put 70 miles on my car every day)
let me know what you think allso if you have any idea on how to get my 60' times down below 2 but i dont think im going to be able to pull it off with my street tires that i have on it
anyways let me know
and my car specs
anyways let me know
Car: 1985 Firebird
thanks man
i need to get some slicks i think lower my 60' time to below 1.9 and hopefully get into the high 12's (key word hopefully) but i still have alot of tunning to do yet on the car i just got the carb set and now im working on timming and the timming curve then i will have to go back to the carb since it will be different cuze of the timming maybe if i get it all set i will see some 12's but i still need to do something with my 60' foot i dont think its that bad but there is room for inprovment in there i think
Two words, torque converter . You need one if all you are running is a stock type converter. Also, kind of a smallish cam for a 377ci small block. Those are the only two observations I made right off the bat. All else looks to be right on track.
Car: 1985 Firebird
umm 377ci? its all standard its a 350ci motor im just wondering where you got the 377 from and its quite a medium sized cam for a 350 you have to remeber its a rollor cam
yeah i think that will be my next purchase is a tourqe converter just a small one like 1500 stall liek you said before i dont have that much of a cam so having a huge stall would be a wast of power im thinking in the 1500 to 2000 range should be about what i need since the start of my power is at about 2500
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If your cam is rated 2500-6500 your probably gonna want like a 3500 stall....yes you read that right. smae parameters as my old cam and got down into 1.72 range 60'. It sounds like alot, but if you stick with a 10" convertor it's still going to be plenty tight to drive around on the street with little to no noticable difference over what you have now. Just menas when you mash it and flash the convertor it's going to be closer to your peak torque and get you going that much faster.
Car: 1985 Firebird
hey josh long time no see......
yeah i thought of that after i posted but hey some more tweeking and i might finally be close to your car
well hopefully ill see you at the track sometime before i move
and good luck this season
well hopefully ill see you at the track sometime before i move and good luck this season
better do alot of tweaking
In about 2 weks the new 388 is getting dropping into place. Paperwork says high 10's but I'm hopeing for mid to low 11's to be conservative.
Steel Crank Stroke 3.75
Car: 1985 Firebird
possably but acording to barry grants websight its the recogmended carb for the aplication ive thought on it and im still running stock jets in the carb so i will play with that sometime this year allso i see alot of people over carb there motor but thats not a concern here just someting i allways keep in mind sometimes more isnt allways better but im sure i could use the air flow of a 700 or better carb with the 2.02 valves and so forth so it allso might be somthing i will experament with the summer
Dont know how many guys argued with me saying the 830 was too big, and now the 950 which actually only flows 830 wet cfm. Everybody can keep they're math equations, I stick to the black and white at the ticket booth. Givr'er more fuel I say, if your gonna buy a carb forget the 700DP-no hop up parts for it, at least invest in a 750DP, and if you can swing it at least a 750HP, but if you want a good all around carb you can grow into, 950HP hands down. 2.02 valves dont have squat to do with carb sizing. It's how well all your componenets work together. I've been here and done this starting with a 600 VS, 700DP, 750VS, 830DP, and now 950HP. Just like evolution the times got better not worse. Worse thing to happen, you load up the plugs street driving. Anybody that tunes for peak track performance with a holley knows there is no middle ground for street/strip. Your either going to run right on on the street and lean at the track, or just right at the track and fat in town.
With the right combination you should/a been smokin me
but I run a carb that's too big so what do I know, lol!!
Car: 1985 Firebird
i didnt meen over carbed that way what i was getting at was most people will take and put a 950 dp on to a stock motor is what i ment by over carbing a setup
and yeah i know i need a bigger carb.... one of these day ill get a new one now only if i can find someone to take mine off my hands
