Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
confused
Old Jun 17, 2004 | 07:22 AM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
confused
hey guys I'm a lil frustrated I just put Nitto 555r's and ram air boxes on my 91 Z 350 and for some reason even after launching at 1500 with no tire spin my car runs what it ran back in december (14.2) same 60 ft (2.09) but a 9.01 1/8th time (2 tenths faster than december. Grant it it was 90 degrees 100 percent humidity and in december is was 50 with 0 percent humidity. I dont know is wether that much of a difference? I do get the service engine light sometimes wehn cruising at a steady rpm could it be a sensor? Im confused.
Old Jun 17, 2004 | 09:05 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
It can...
WARNING: YMMV
http://www.staginglight.com/guide/weather.html
In short, heat slows you down, humidity slows you down, and dense air pressure helps speed you up. After a year of record keeping with the gauges, I have come up with the following simple rule that works for my car:
Temp goes up 3 degrees, ET slows .01 seconds
Barometer goes down .01-.02, ET slows .01 seconds
Humidity goes up 5%, ET slows .01 seconds
By this guys estimates you should have ran a 14.53 based on the conditions you described. So you "gained" about .33 seconds with your mods. The real test to see if you ET improves will be when conditions are better.
Old Jun 17, 2004 | 11:51 AM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
wow thanks didnt know it made that much of a difference. Great info. Thanks!
Old Jun 17, 2004 | 02:34 PM
MdFormula350's Avatar
with radials and a 350 tpi you should be able to hit up 1.8 60 foots, maybe try and get on the gas earlier.
what mph did u run?
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
