would this rear battery pass tech
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
would this rear batter mount pass tech off this website?
http://home.fuse.net/dual-slant-4/Re...atteryBox.html
seems to be mounted with 3/8" threaded rod, sealed to outside of cabin, etc. etc. has cut off switch. any thoughts?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks good to me also however it still must pass a tech inspection.
The rules state it must be in a sealed .024" steel, .032" aluminum, or NHRA accepted poly box. I guess sending all the specs and Walmart part number to NHRA tech and asking them would be the best way to know for sure.
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
