Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
cheap solution....will it work?
Old Aug 15, 2004 | 12:51 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
hi,
i want my 87 camaro powered with a 355ci to hook up better.
got a stock suspension with a NON-posi rearend.
my right rear wheel is always spinning badly during acceleration.
so what i want to do is to put a solid bar between my right rear spring so it is kind of stuck.
will this work? (i know it wont be comfortable, but it is only for racing)
thanks
Old Aug 15, 2004 | 08:37 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
The better solution would be spend the $60 for the air bag kit If your running a non-posi rear you still wont have a chance and imo putting a solid stop would only make the situation worse since you would be transfering no weight and all the force would have to be absorbed by the tires. Alright for a big tire rail, but for a full body car your asking for troubles. Unfortunately there is no such thing as cheap solutions for ligitimate solutions.
dutch930
Sep 11, 2015 06:58 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
Jk_Under
Aug 17, 2015 03:08 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Leggman1
Aug 6, 2015 04:15 AM
