Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
new combo...for now
Old Aug 22, 2004 | 06:22 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
new combo...for now
i was just wonderin what u guys think ill run for a 1/4 mile time with my recent swap...?
i changed out the tpi 305 for a 350 bored .060 over, 850 holley carb, edelbrock torker single plane intake, comp cam (dont know the exact lift; noticable idle tho..), 58cc 305 heads fully ported and polished, headers, electric pump and holley regulator, MSD wires, new distributor, with a rebuilt 700R-4 with b&m street strip shift kit, holeshot 2400 stall, 3.42 gears and 23.5 inch slicks....
Old Aug 22, 2004 | 06:29 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Without knowing cam specs.. at least duration, and or LSA..
Hedders 1 5/8 or 1 3/4 ? Long tube or shorties ?
Thats a lot of carb ...
without knowing cam specs, I dont know how ppl would know where your peak torque # are ..
Old Aug 22, 2004 | 06:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A guess? ok. 14's. You want to know what it will run, take it to the track and find out.
23.5" tires? What are they off of, a Mini Cooper?
Old Aug 22, 2004 | 06:48 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
So that's where my kids go-kart tires went!!!
low 14's high 13's 97-98 mph
Old Aug 22, 2004 | 10:39 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Are those tires on 15" rims? If so, there wouldn't be a lot of sidewall.
The combo may be good for low 14s but it's really hard to tell if things are matched up properly without knowing the cam specs. You have a big carb and a single plain yet a pretty low converter for the cam you'd need for the carb and intake.
Old Aug 22, 2004 | 11:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I just did a quick search to see if I could find that size "slick". MT doesn't have anything that size, Goodyear doesn't have anything that size but Hoosier lists a 23.5 x 11.5 x 16 road racing slick but it's designed for a 12" wide rim (open wheel stuff)
Old Aug 22, 2004 | 11:04 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
A guy on a local board here posted about ordering M&H 23.5x7.5x15s for his turbo dodge today. Maybe that's what his are.???
Old Aug 22, 2004 | 11:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Using a tiny tire to compensate for poor gearing is a step backward. The small tire puts a very small contact patch on the ground from front to back of the tire and will really limit traction. The proper way to select tires is to stuff the tallest tire possible into the wheel wells then select the best gearing to work with them.
Width is just another factor. While most cars can easily survive with only 9" of tread, going too wide with a low HP car just creates more rolling resistance.
He's using a 23.5" tall tire with 3.42 gears and a 700R4 tranny which has a too low 3.06 first gear even for 26" tires. There's a combination that can smoke the tires and not get anywhere.
Also at 60mph, the engine would be turning just under 2600 rpm in OD where a normal 26" tire would have it just under 2400 rpm.
Old Aug 25, 2004 | 05:17 PM
Car: 91 camaro rs
tires
the tires are McCReary tubless slicks, 15x7.5x23.5 and yea i plan on doing the rear end with lower gears something like a 4.10 or 3.73 in the near future...
Old Aug 25, 2004 | 05:32 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Re: tires
Are you still going to run the tiny tires with the steeper gears?
That would limit you to 112.5mph @ 6000 rpm with 3.73s and 102.3mph with 4.10s.
4.10s with 23.5s would be like 4.56s with 26" tires and 4.90s with 28" tires without the benefit of a normal sized contact patch.
