Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Turbo mini van beats an Iroc-z
Old Oct 3, 2004 | 12:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep, at the track. Those minivans are slow, but this "Iroc-z" is alot slower. They say its an Irocz TPI but seriously run that slow?
http://www.turbominivan.com/videos/clif_roc.mpg
Old Oct 3, 2004 | 01:03 AM
MdFormula350's Avatar
cant win every race i guess.
Old Oct 3, 2004 | 01:21 AM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
that van isnt stock ill tell u that i think its got a engine swap and a turbo setup theres a site out there that explained it all it was a dad who made the family van into a sleeper he was workin on it for like a couple of years but now he died so who knows maybe mommy is usin it now to get her groceries
Old Oct 3, 2004 | 03:49 AM
stu
Guest
Posts: n/a
There are a couple of fast turbo minivans out there. I think they came stock for a couple of years too.
There is a full size Chevy G20 van at our track that clicks off 13's at like 108 mph or something. That's pretty sweet, especially at this altitude.
Old Oct 3, 2004 | 10:45 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've seen as Astro van with a V8 in it. It's like everyone expects a third gen to have a powerfull V8 under the hood but there are many with only a V6. Then they say "Is that all it ran?" without knowing it has a V6.
Same as first gen's. Everyone seems to think all the 69's had 396 big block. Many either had a straight 6 or a 327.
Body styles can be misleading. You can never underestimate what's under the hood. How about a Monte Carlo SS with the 305 ripped out and a 500 Caddy engine sitting in it's place.
Old Oct 3, 2004 | 12:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
that van ran a 16 flat it looks like in the video. IRoc is way behind that. How many 305 TPI irocs run high 16's or slower? The car didnt look like a beater either.
Old Oct 3, 2004 | 12:57 PM
Airpak's Avatar
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
http://www.turbovan.net/van.html
this turbo minivan runs 12's
http://www.turbovan.net/pauls_van.mpg
Old Oct 3, 2004 | 04:27 PM
Marc 85Z28's Avatar
First, the van ran a 16.03 at a whopping 83mph. That's not fast at all. Second, the IROC was available with both the 155HP LG4 and 170HP L03, both usually equipped with an automatic trans and poorly geared rear with an open differential. Most stock LG4s or L03 would be hard pressed to run a 16 flat, much less an older one out of tune. Still it could have been a TPI, as most are in horrible running condition, but more likely one of the two listed above.
Old Oct 3, 2004 | 05:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A brown one, by any chance?
If so, it's a full size short wheelbase Dodge van, with a 496 Mopar. Runs mid-12's, all motor. Always a crowd favorite.
Old Oct 4, 2004 | 10:53 PM
nick418's Avatar
Engine: L98, Hemi 6.2
ive seen this vid, Also seen a Van like that beat up a Lt1 or Ls1. i think Ls1. Its video online as well. The prob has a Lg4 or LO3. Runnin 16s like that
Old Oct 6, 2004 | 01:25 AM
chevelleguy's Avatar
a chevy g series van should run the same as a chevy c series truck because....they're the same, the body is obviously a bit different, and the van is the only thing I could imagine being more aerodynamically challenged than a truck, but the frames and suspensions were about the same and the engine options were usually similar, all else being equal the only thing that should divide them would be the aerodynamics or in the case of the van they should probably be called aerostatics because I can't even imagine getting one to go over a hundred, I've got a g30 chevy van to haul parts and I have to say I'm usually pretty thankful its a tank when the bigrigs go by at 80, feels like its about to get on two wheels and fly off the road
Old Oct 6, 2004 | 07:04 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
most likely not a tpi car..
Old Oct 9, 2004 | 09:00 PM
jksstar's Avatar
Car: 1985 IROC Z28 and 99 Nissan Altima
Engine: 305 TPI / KA24DE on N2O
sorry to get off topic, but I have a 85 IROC with the 305 TPI and I'm lost I hear poeple talking bout LG4 and L03 alot and I don't know what they are ( I know they are 305s but are they carb or what ) aslo what one do I have? Sorry for the dumb ?s, its my 1st domestic.
Old Oct 9, 2004 | 10:03 PM
nick418's Avatar
well you just said that you have a 305 tpi, also use your PMs. B4 mods get pissed
Old Oct 10, 2004 | 01:00 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thats no stock 2.5L turbo van. A stock 2.5L turbo van is very responsive and fun to drive until 40 MPH but you would be hard pressed to get it above 80MPH. I do know they will take a stock 305 TBI until the 60 mark but after that no chance.
There was a guy that worked over at autozone that had a pimped out low rider Astro van, I seen it around town always going 20+ over the speed limit. One day I asked him what kinda setup he had, pop'd the hood and sitting in place of the 4.3L was a chromed out 406 steralth ram engine with a paxton SC neatly tucked in. The thing sounded stock too
Old Oct 10, 2004 | 03:46 PM
Marc 85Z28's Avatar
There's a LOT more to this site than just message boards. On the www.thirdgen.org main page, there is a list of very useful resources and information on the left side of your screen. What you want to know can be found within those links. Pay close attention to the Tech Data section
Old Oct 10, 2004 | 04:11 PM
jksstar's Avatar
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88CamZ
Oct 8, 2015 10:29 AM
bjpotter
Oct 4, 2015 07:48 PM
09ave
Sep 7, 2015 06:03 PM
