Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
WS6 launch pic
Old Nov 14, 2004 | 04:24 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
WS6 launch pic
Just wanted to share one of my launch pics. This is on street tires with all stock suspension and the sway bar ON the car with a bolt on 305/700R. This pass was a 1.834 60 ft.
Old Nov 14, 2004 | 04:25 PM
Engine: LB9/383
man, it wont work. Well, it's the same car as in my sig. The front end was a little higher and it had the stock GTA wheels on the front.
Old Nov 14, 2004 | 06:04 PM
megaracerx's Avatar
:hail: to the sig pic
Old Nov 14, 2004 | 06:34 PM
V6camaroman's Avatar
what have u got done to that 305 700r4 combo. thats a mean launch. i right clicked and saved as on that one. i want my camaro to launch like that. it would pick up even higher if u took off that sway bar and got some drag shocks and some 26" tall slicks.
Old Nov 14, 2004 | 06:39 PM
Engine: LB9/383
I just got the link to work
It's got a 2800 stall, 3.42's and SFC's.Those are the mods that help the most to get it to leave like that. I've got some LCA's to go on but they're still in the box.
Old Nov 15, 2004 | 05:16 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
this is funny.....this is a video of my camaro doing a 1.69 60 foot, it doesnt even squat or lift in the front. lca's and relocation brackets,36mm/24mm sway bars,kyb gr2's, sportline springs,its runnin on 87 octane and has 1 1/2 flowtech shorty's. its has stock vortech heads with stock size manley stainless valves, 284xe cam, crap gm vortech intake with 1 in spacer and 650 dp, its a stock used 350 standard bore truck shortblock, a used 350 turbo(didnt even change the fluid) from a van in a junk yard, 3200 stall,3.23 gears,255/50/16 bfg dr's, no a/c no heater no power steering. had 4th gen leather seats and no sub frames. the car weighed 3280 with driver. i built the motor for a total of$985 with tax, fluids and gaskets(i worked at a performance shop, and got everything at cost).
http://www.rcbproductions.com/video/...8_vs_redta.wmv
just thought it was a funny compare. my car is going low to mid 12's(8.0 1/8 mile in video) and looks like it isnt doing anything! great pics of the trans am! saved them too!
Old Nov 15, 2004 | 07:32 AM
Engine: LB9/383
those stiff springs/shocks and the swaybars help keep yours on the ground. Get a drag setup on there and you'll be in the 1.5 60 ft. times!
Old Nov 15, 2004 | 03:03 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
i could have, but i wanted a car that could handle very well, and im not taking my front sway bar off. besides the less power you use to transfer weight, the more is used to propel you forward. i think it was really decent for a $985 doller motor on 87 octane. and i didnt change anything on the car, i drove it to work and drove out to the track later that night and changed nothing. it didnt spin at all....after a 10 sec burnout.
Old Nov 15, 2004 | 03:12 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
My ***. I hope you have good subframe connectors..
:hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail:
Old Nov 15, 2004 | 03:33 PM
slim84maro's Avatar
Car: 86 Camaro
Engine: 5.7 with some mods.
Transmission: 700r4 needs shift kit
Axle/Gears: Stock.
i dont have sfc and my car does that.
i also have stock suspension and stock most things.
never been to a track either.
what will taking the front sway bar off do?
i might take mine off
Old Nov 15, 2004 | 05:18 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
man, my torque converter is really holding me back still! 13.75@100mph with a 2.03 60' and no tire spin. (310/700r4/3.73's/28" tire, more mods in my cardomain site)
Old Nov 15, 2004 | 08:38 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Wow you guys are getting lucky...
I dump the clutch like 5200 and hit 1.69 60's and my car doesnt even come close to that much weight transfer. I also run slicks, on street tires my car just goes!
Old Nov 15, 2004 | 09:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
even on my 1.94 time, i felt a good bit of movement. I probly can get more if i set my rear shocks to softer setting
Is that right? soft shocks up front and rear to help weight transfer. i always thought to have front soft and rear a bit stiffer to control transfer and rearend.
Old Nov 16, 2004 | 12:55 AM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Even on my 1.77 short times I don't think the car lifts like that. Ever since I went with the Eibach Pros I noticed the car doesn't lift like it did but it still dead hooks. Nice pic, that one is a keeper!
Old Nov 16, 2004 | 07:30 AM
Engine: LB9/383
Yeah, it's got sfc's. It's always good to keep the car as level as possible to use the power for forward motion and not upward, but it makes for good pics It got me to the finals so I can't complain.
Old Nov 30, 2004 | 02:55 PM
anymethod's Avatar
Car: 1986 Trans Am
Engine: carb 305 LG4
Transmission: TH700-R4
I only have one question: Did you beat the Camaro thats next to you in the pic?
~Matt
Old Dec 1, 2004 | 08:19 AM
Engine: LB9/383
That pic was from time runs, so HEEEEELL NO! But I did beat him 2nd round.
Old Dec 1, 2004 | 09:05 AM
anymethod's Avatar
Car: 1986 Trans Am
Oh nice. What times do you generally run?
~Matt
Old Dec 1, 2004 | 09:58 AM
Engine: LB9/383
usually dial 14.56-14.62 depending on weather.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
tuningnewb
Sep 23, 2015 07:06 PM
gt4373
Sep 9, 2015 10:29 AM
dbrochard
Sep 7, 2015 09:41 AM
