Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Fastest a 305 TPI will run with not alot of mods
Old Feb 15, 2005 | 12:59 AM
Hoppy72442's Avatar
Car: 1986 IROC-Z28
Engine: 305 TPI H.O.
I want to know how fast a 305 TPI can run in a 1/4 like air conditioner working and every part that came on it just tweaking the motor a bit but not enough people can tell whn u raise the hood ? Thanks guys
Old Feb 15, 2005 | 01:01 AM
Hoppy72442's Avatar
Car: 1986 IROC-Z28
Also wood like to Know what i could do to my 86 IROC-Z
I also have a 1986 305 TPI and wondered what i could do to it so far i have dremaled the Tune port out and added a Hypertech Power performer 3 chip and took out the ram air restricter plates out but wood like to know what to do next i wood say it wood run in high 14's now and its an automatic..gets a mean 2nd to also have lightened the load a bit and fixin to have the Plentium ported and chromed or polished i was told that wood gain u 20 ponys and thinking of getting a better cam everyone says the stock cams are ****y but i dont know alot about raceing last time i race was back in high school at George Rays track in Paragould Arkansas its only 1/8 ..Thanks guys
Old Feb 15, 2005 | 01:02 AM
Hoppy72442's Avatar
Car: 1986 IROC-Z28
And could someone also tell me how to put a pic under my name cant figure it out ?nm i figured it out
Old Feb 15, 2005 | 04:49 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
when my 91 G92 LB9 was factory it ran 14.4's@ 93 mph...only mods that i did to the car were a set of tires (good street tires) added a flowmaster exhaust, K&N filter ground down the EGR walls in the plenum...the car ran a 14.12@almost 96....
keep in mind this was a 5 speed car with 3.42 gears AKA a "G92" car...and i can drive the crap out if it....
now its got a bit more steam under the hood
Old Feb 15, 2005 | 05:42 PM
Hoppy72442's Avatar
Car: 1986 IROC-Z28
thanks for the info but do u know about any easy bolt on performance parts.I also have a 1986 305 TPI and wondered what i could do to it so far i have dremaled the Tune port out and added a Hypertech Power performer 3 chip and took out the ram air restricter plates out but wood like to know what to do next i wood say it wood run in high 14's now and its an automatic..gets a mean 2nd to also have lightened the load a bit and fixin to have the Plentium ported and chromed or polished i was told that wood gain u 20 ponys and thinking of getting a better cam everyone says the stock cams are ****y but i dont know alot about raceing last time i race was back in high school at George Rays track in Paragould Arkansas its only 1/8 ..Thanks
Old Feb 15, 2005 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I saw a stock 350 TPI run 13.0's at 5800' elevation Bandimere a couple of years ago.
Stock except for that nitrous plate behind the TB. And used circle-track slicks on the rear.
Sea-level with a 305, should be able to duplicate that.
That's about the cheapest bolt-on you can get, bang-for-bucks wise.
Old Feb 16, 2005 | 05:52 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
well you have to remember with a 305 or 350 you can do alot of stuff to the motor and the average joe will not know that you have anything done like for instance 1.6 roller rockers how are they going to know? they cant see them. if you go came just dont get one with alot of duration thats what makes it idle choppy and gets peoples attention i thinks thats why i cant get a race to save my life it barely runs. but anyways. port match the heads and intake little stuff like that. even headers most people think headers dont help that much but they do plus they make the exhaust sound so much better. you can even put vortec heads unless you know what to look for you wont even know. hope that helps you out
Old Feb 16, 2005 | 07:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
two words to going fast with minimal power adding mods:
WEIGHT REDUCTION
my car weighs 3045lbs. with traction, i am in the 13.60's. with my new high stall converter and tranny with shift kit, i should be in the 13.20's.
Old Feb 16, 2005 | 07:39 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
13.99 @ 100 for a stock 92 B4C 1LE Ex-DPS Camaro, with no more than a cat back exhaust. That is what a PO did with our car. I hear that is a common ET for B4C 1LE cars.
Old Feb 17, 2005 | 03:35 AM
Hoppy72442's Avatar
Car: 1986 IROC-Z28
i think firat thing i gonna do is take the heads off shave them down then port them out and put valves in them off a 350 instead should do alot more ponys then do cam and maybe catback
Old Feb 17, 2005 | 07:21 AM
mw66nova's Avatar
Engine: 7.0L
do your catback first. i have stock heads on mine and it's going mighty fast.
Old Feb 17, 2005 | 07:39 PM
Hoppy72442's Avatar
Car: 1986 IROC-Z28
Yeah i think i do that first then
Old Feb 19, 2005 | 08:17 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
66nova hit the nail on the head......weight reduction. My 305 car
went 14.55 almost totally stock, but its a hardtop (-37lbs), T5vs auto (-100lbs), no air(-40lbs), pulled the passenger seat(-40lbs), pulled the spare/jack (-45lbs). Adds up after a while...
Old Feb 21, 2005 | 10:42 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
High 11's.........
Attached Thumbnails Fastest a 305 TPI will run with not alot of mods-c-burgess-z28-photos
Old Feb 21, 2005 | 11:12 AM
mw66nova's Avatar
Engine: 7.0L
so, how much are you sprayin? lol! seriously though, what is your setup there buddy? been looking for the last two years about hopped up 305's and never once have i heard from you.
Old Feb 21, 2005 | 11:31 AM
11's with 125 hp nitrous - it runs high 12's on the motor alone.
The short blk is stk with 180K miles on it (I'm the original owner & I attribute the motor holding together for so long to Mobil 1 Synthetic), and the heads are stk ported LB9, TPIS intake, runners, TB, plenum, SP-L98 cam, 1.6:1 roller rockers, Edelbrock headers, Flowmaster cat back, Richmond 6 spd, Moser 9" with 35 spline axles & a Detroit Locker, Wide band O2 system & I burn my own PROMs.
Old Feb 21, 2005 | 01:08 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Hell f'n yeah!
Old Mar 3, 2005 | 09:59 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
sweet ride tim
LB9GTA
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
