Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
will this get me below 13.5~ @105~
Old Feb 26, 2005 | 09:02 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
this is my new combo, --'85 trans am, 3150lbs w/ driver
'72 350 bored .060" over---("desktop dyno'd" 382hp/405ft/lbs...)
58cc 305 H.0. heads ported/polished
edelbrock rpm air gap intake
lunati bracket master 230deg.(292advertised)480" hyd. cam
demon 700dbl. pump 4bbl
edelbrock TES headers
flowmaster 3" american thunder catback, w/ no cat
jegs aluminum radiator
'88 700R-4
master overhaul rebuild
corvette servo
superior shift kit
b&m holeshot 2400 stall converter
'86 drum rear
richmond mini spool
3.42 gears
hoosier quick time 26x9.5x16 slicks on 16x8s-rear
kumho ecsta 712 225/55/16 on 16x8(40psi)-front
Can i get mid 13's at 105ish? Or quicker?!?!?! any advice or thoughts would be appreciated
Old Feb 26, 2005 | 09:12 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you can get close to that horsepower and with the weight of your car you should be in the 12's with no problem. Remember you have to get that power to the ground. So you will need good drag tires and proper suspension mods.
I have a car that is around 3800 pounds race ready with me in it and with 354HP at the crank I have turned a 13.30 in the quarter. With the weight alone you would be 6 tenths quicker.
Something else you might want to think about is the B&M governor kit to adjust your shift points. Mine was shifting around the 5000 mark stock with the 700R4. See where your shift points are and adjust accordingly. Allen
Old Feb 26, 2005 | 10:07 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Id hope so, Im right near that race weight with 272 rwhp (maybe 320 flywheel if that) and have gone high 12s on radials and mid 12s on slicks with no suspension mods. I would say you should theoretically be deep 12s with that power and weight so long as its geared right!
Old Feb 26, 2005 | 11:43 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
how are you so light? is the car stripped? ihave all *necessary* street equipment and weigh 3300 w/driver, 3045 w/o.
Old Feb 27, 2005 | 11:26 AM
njspder's Avatar
Car: 1976 Camaro LT
Transmission: TH350
it sounds liek a strong combo to me. i would look for 12's. prolly something 12.7ish at about 106.
later
tim
Old Feb 27, 2005 | 05:23 PM
Car: 91 camaro rs
the car has 3.42's now, but will be changing accordingly after i run it and see what im rev'ed at the end of the 1/4... im thinking of a 4.10 with the 26" slick should allow a possible 115 trap speed...(redline is around 6500ish)
and the car's weight reductions is
deleted:
AC and heater off firewall
all AC pump, pulley, belts, condenser, hoses..
A.I.R. pump, bracket, belts,
power steering (for now.)
windsheild wiper resovoir, motor, and wipers,
radio, heater, carpet, door panels, back seat, all plastic trim except dash,
with plastic race seat.
and i weigh 135.
Old Feb 27, 2005 | 08:32 PM
mw66nova's Avatar
Engine: 7.0L
ok, so you have a stripped interior and only weight 30lbs. less than me! my goodness man, put that interior back in the car! it only makes the car less complete! just take the sound deadening material off! i weigh 256lbs, which is why my car seems heavier than yours, but in reality, it's just my big butt that wieghs more than your scrawny self!
Old Feb 28, 2005 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
13.5 @ 105 sounds to me like all top end and no launch.
My shoebox hit 12.9's at 102 at 3880 lbs. (de-tuned in an attempt to hit 13-flat) - never dyno'd, but estimate 400 GFWHP, 325 RWHP. Of course, 700 lbs lighter and better aerodynamics should help your MPH, but the lower weight should also help the launch.
For reference, it was hitting 103 mph 2 years earlier with vacuum secondaries, less stall, and open exhaust - but only 13.5's. Going to DP and more stall moved 60 fts from 2.05-ish to 1.75-ish - and took more than a half second off ET with no increase in power.
What a difference a launch makes...
b4ccamaro
Jun 5, 2016 01:48 PM
Night rider327
Sep 25, 2015 04:19 AM
tuningnewb
Sep 23, 2015 07:06 PM
Blade
Jan 29, 2001 07:13 AM
Blade
Jan 12, 2001 01:45 PM
