MSD 6A made a difference !
Old Jan 18, 2001 | 01:43 AM
Blade's Avatar
Bought a plane ol MSD 6A from Checker Auto Parts today and the GM adapter for the harness. Being a non believer I thought... "I'll buy it, try it on, and prove my buddy that people over at thirdgen.org are right... MSD 6A's dont give you any horsepower increases or better throtle response whatsoever!".
Well I have to say I LOVE IT. As soon as tapped the gas to get out of my parking space in the Checker parking lot (I put it on in the parking lot) I could tell a difference. Took it down the road and the throtle felt like on a new LS1. Nice and smooth and pulled all the way up to red line. On the G-Tech it gave me 2 tenths. I can definately tell the engine revs faster especially in they higher RPM range where our engines really need any help they can get. I'd say this is a good 100 bucks spent even for the MUCH better throtle response alone.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
[This message has been edited by Blade (edited January 18, 2001).]
Old Jan 18, 2001 | 07:07 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
It just goes to show you that every car is different. I noticed absolutely no difference with mine. In fact, I could not tell that it was even working. So I sold it three months later for $50.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Jan 18, 2001 | 02:54 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'm beginning to believe that the MSD ignition is a band-aid for a failing or inadequate stock ignition. You probably have a loose wire, or a coil on its way out, or something else that the MSD is making up for. My drag racer friend told me that his MSD 7 doesnt even make a difference until he gets over 6500 RPMs.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 18, 2001 | 03:52 PM
'89Formula305TPI's Avatar
I pretty much second what Kevin said.
when I installed my 6-AL, I also changed all ignition parts including blaster-2 coil.
And from that load of money spent, I can tell you it was not worth it.. of course all that tuning starts from those little things, but I think that if I had left them wires, plugs, cap, rotor and coil not installed, there wouldn't be any difference.
I think so?
'89 Formula 305 TPI T-5
Check out my car HERE!
Old Jan 18, 2001 | 04:05 PM
Blade's Avatar
Well my engine only has 3000 miles on it so it's pretty new. I have a NEW distributor with a new cap and coil and new MSD 8 mm wires with Rapidfire plugs. Adding the box to THAT setup made a difference. It's mostly throtle response but that alone is worth it to me. I love excelent throtle response with no stumbling or flat spots or bogging of any kind.
92 Z28 L98 350
Old Jan 18, 2001 | 06:46 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
I'd say that an aftermarket ign system, like MSD, does probably make a difference, but only above 4500 rpm, or so, where the stock ign system output starts to drop off. You would also probably notice a greater difference if you were using nitrous, or forced induction.
Tim
Old Jan 27, 2001 | 06:20 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
I just installed a MSD 6-AL last night with the blaster coil. I haven't driven it on the street yet, but it starts up easier and it holds it's idle speed, instead of stumbling then catching and reving up for no reason. I like it so for, I'll let ya know ho I like it on the street soon.
Old Jan 29, 2001 | 07:13 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Well,I can honestly say that it works for mine. I unhooked it once to diagnose some ignition problems and after fixing them I decided to try it out without the box. After only one trip around the block I hooked it back up. It made a real difference.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Fanatic1074
Oct 3, 2022 05:57 AM
sreZ28
Oct 22, 2015 08:21 AM
Roshambo
Sep 12, 2001 11:31 PM
SAEspinz80
Aug 26, 2001 04:10 PM
Z28HO
Carburetors
Oct 5, 2000 02:58 PM
