FINALLY got some CARBED LT4 times
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ok its been a long time waitng for me and im sure a few guys have been waintg to see what it would of done...well i got 4 runs in..they were have some timing problems so i only have 60ft 1/4 and trap
1st race..
60ft 2.43
...first time launching it spun its *** off
1/4 13.22
TS 116.77
2nd race
60ft 2.23 ...bogged a little then took off and spun
1/4 12.86
TS 115.64
3rd race
60ft. 2.09...spun very little and didnt bog best 60 of the bunch
1/4 12.54
TS 115.12
4th race
60ft. 2.15....spun a little more then 3rd run
1/4 12.61
TS 115.23
overall im pretty happy with it so far...this is with a box stock 650DP with stock jets and everything....with some tuning its got another 2mph in it easy...i didnt powershift it so theres another 1.5-2 tenths but i dont wanyto break it so thats not gonna happen....im going back soon with some slicks so maybe i can get a low low 12...its got the power for an 11 but like i said im not gonna break it for a time slip....
when i put it together i was shooting for mid 12's so i met my goal, and it can only get faster with traction and tuning...
1st race..
60ft 2.43
...first time launching it spun its *** off1/4 13.22
TS 116.77
2nd race
1/4 12.86
TS 115.64
3rd race
1/4 12.54
TS 115.12
4th race
1/4 12.61
TS 115.23
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah those speeds are good for bottom 12's and high 11's with good traction. you could be in the 1.7's in the 60foot and run high 11's
very nice!
very nice!
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Glad to see you are already very close to your goal. Let us know how you make out with good tires.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Originally posted by f-crazy
wow i was expecting alot more replies then 4
Dang, nice times! I wish my TPI pulled like that
A while back in CarCraft, they stuck a stock carb on a stock LS1 and made something like 420 hp! I would imagine an LT1 would make close to that. Nice times bro
Engine: CARBED LT4
Transmission: MK6
Originally posted by RWB____s
what tire combination were you using when you ran those times?
this motor was runnin almost 109 with the stock cam, long tubes carb and dual exhaust..and i cant recall who did this but the carb and EFI setups were tested againts each other everyhting being stock other then the induction and the carb produced more low end grunt by 25+ lb ft. and like 20 ponies at 5,500..this carbed intake really works..
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
i'm astounded by the mph. it does seem to slow in mph with decreasing 60s which is pretty typical, IMO. I need to know the weight of this car. What has been done for weight redux? Those aren't corrected are they? what track was that?
How in the h%^$ does an lt4 with a carb go 115 plus mph? Pretty rare results I'd say. Good work. get some tires on it and post the actual timeslips!
Engine: CARBED LT4
Transmission: MK6
im going back soon becasue my slave started to leak so its hard to shift now so itll be a little while...but it will be with slicks and 7 pounds of fuel pressure....then maybe ill get the carb tuned...
the plugs look pretty good so its not thin..so well see what a dyno tune can do for it
Car: 1991 Firebird
Engine: 427 LSX
i think you meant to say "not corrected" My best times were also run at Milan, fyi.
Anyhow, good job, I really wouldn't expect that kind of hp! Alot of 383s with more cam, head, and carb, dont mph that well. I could site many many examples.
how much do those heads go for? are yours ported? flowed?
Engine: CARBED LT4
Transmission: MK6
yea i maent they dont ned to be corrected...or i could of left off the "ed" part lol...milan is a good track, its really sticky and they just redid the launch pad so its good to go....NIB LT4's go for 600 a piece bare castings...i paid 1200 for mine assembled with Hotcam springs manly 2.02 1.60 proflow valves (stock is 2.00 1.55) and drilled for 7/8 studs so i got a good deal on them...there as cast but im going to get them ported by Lloyd Elliot who routinly gets 300 cfm out of them....i had them flowed when i bought them and they flowed almost 260 and 210 exhaust...which is about what afr 195's flow....the LT4 intake port is also 195cc..
when i get them ported im gonna sstuff a GM 847 in there and put down 425-430 to the ground....
its all about the combo...a lot of guys just throw **** together and expect it to go fast...these LTx motors make a lot of torque..so i built for that andd the HP will take care of itself
my LT1 powerd 9C1 caprice makes gobs of grunt...were talking almost 350 ft pounds @2,400rpm amd its flat as a board
Polo Z03
Sep 10, 2015 06:43 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Friend of mine ran an 11.92 @ 114 mph with a 1.86 60'.
